front end alignment after power steering conversion
valveamp
Hi Everyone.
I just got my '71 back from the shop after a conversion to power steering. The shop told me to get it aligned as they are not equipped to do that. The steering gear box is the 4x4x2 box and uses a, roughly, 1/2" thick frame reinforcement, which spaces the steering gear over from the stock location. The truck has about a 3.5" inch suspension lift, no body lift and uses the standard pitman arm and track bar. I've never had any steering problems with this setup. When I drove the truck, yesterday, I noticed that the steering wheel is now off-center, to the left, from what it was before. What needs to be done in order to get the wheel recentered? Is this just an adjustment, or do I need new parts, like, maybe, a fully indexed pitman arm? The steering linkage is completely stock, but it has been rebuilt in the past. Thanks for the help.
ScanmanSteven
Couple of things come to mind. If the steering is centered, meaning the same amount if turns to full left, center then full lock right. If that is equal then just pulling the steering wheel and recentering it should work. With the suspension lift the body might not be centered anymore so you'll need an adjustable trackbar. Also need to have your drag link and track bar as close to paralle as possible. Hopefully others will fill in missing info.
Is your steering linkage still stock valveamp? If so, then I'll say that instead of re-orienting the steering wheel, get an adjustable draglink instead.
And yes, I sell them, so "that's easy for me to say" of course ;D, but it's also the right way.
If your steering box is off-center it's not happy. And usually neither are you after a while. An adjustable draglink (which is a minimal no-brainer on just about every OE car or truck out there except EB's for some reason!) will allow you to re-center the box, and put your wheel back to center also, without moving anything but the linkage.
That's the idea behind the adjustable trackbar that Scanman recommended too. Getting everything back to center, or back to where Ford designers intended it to be.
You're already an unusual one, having that 3.5" lift and still liking the way it drives. Usually by that time everyone is complaining about how squirrely it is, and wanting the corrective factors like the dropped pitman arm and trackbar brackets (or riser) to get it back to sanity.
Any chance you can post up a pic of what your setup looks like? A front shot showing the linkage, and a side shot showing how the box was mounted would be great.
Since you're not a contributor, you can't just post images to the site directly. But you can use a free hosting site like SuperMotors or whatever. Or e-mail to one of us and we can post them up for you.
But it sounds like a draglink, trackbar, and maybe even an arm and bracket are in your future.
V
valveamp
Well, after your comments, I went out and took a good look at my front steering and suspension. The Bronco was lifted when I got it, so I never really took a good look at the steering, I never had any problems with it. Well, it looks like I already have an adjustable track bar installed. No drop track bar bracket, though. Also, it looks like I have an adjustable drag link as well, with no drop pitman arm. I've never had any issues with bump steer. It looks like I just need to adjust the drag link to get my steering back to center. By the way, the 4x4x2 steering gear box is mounted to the frame using Bronco Graveyard's 3/4" adapter, so it's actually moved off the frame by 3/4" not 1/2" as I was thinking.
bknbronco
North Metro, MN
Start by making sure the box itself is centered. If it is then make the drag link longer or shorter, by turning the tie rod ends. Changing a box doesn't change anything in the alignment department. If the shop that installed the box couldn't get your wheel straight then they suck. It would take me about 5 or 10 min max to get it corrected.
Like you already said you moved the box out 3/4" so you need to make that drag link 3/4" longer as well. Hopefully you have that much adjustment. Don't just go off what you steering wheel says....it may not have ever been centered in the boxes center. Center the box then see what the rest says to do.
Do youself a favor and run a broom handle up the tire on both sides and check to see if your body is centered over the axle. If it isn't then adjust that trac bar, then adjust the steering.
V
valveamp
bknbronco, Could you give me some more detail on that broom handle technique?
70_Steve
Old Guy
do.
I would suggest not adjusting the trackbar based on measurements to the body. The body can shift on the frame quite a bit. Make your measurements from the frame to some known point on the front axle. Center of ball joints, top of the wheel rim, etc.
There are measurements you can do to see if the body is centered on the frame. Measure from the frame to the rockers on each side (if you still have rockers) for example...
Hozr
Rogue Valley, OR
There isn't all that much you can actually "align" on a EB; Toe is it and you don't need a shop to do it. Measuring toe from anything other than wheel:wheel will give you false numbers. you will NEVER see a good alignment shop measuring from the frame or any other fixed point on the chassis. There are too many variables between all the moving parts. What you are looking for is TOTAL TOE IN/OUT from wheel to wheel.
To set toe:
Find the flattest piece of ground possible
Place a piece of masking tape horizontally across the front of each tire as close to the center as possible.
Draw a vertical line in the center of each piece of tape.
Measure the distance betwteen the two lines.
Roll the bronco backwards to the tap rotates to the rear of the tires (1/2 rotation)
Measure the distance between the lines.
The difference between the two numbers is your total toe out/in
Once you set the toe then you can center the steering wheel by adjusting the tie rod length.
Gonna have to disagree with you a bit here Hozr. Not outright, but in certain details.
There isn't all that much you can actually "align" on a EB; Toe is it...
While party true as far as some shops are concerned, and with original stock linkage, this is the limit for easy quick adjustment of alignment settings.
But if you don't limit yourself to the original parts, every normal aspect of a Bronco's alignment is adjustable in some manner.
In the case of the caster and camber, it's not a factory adjustment and involves adding parts. Easy though, and fairly standard practice. Just that many shops don't remember, don't want to, or the owner doesn't want to spend that much money. But it's easily doable by shop or shade-tree mechanic.
All I'm saying is that, while not technically "adjustable" from the factory, it's easily changeable, or adjustable with the simple addition of aftermarket alignment stuff.
Just wanted to add that detail to your statement.
Not following you here unless you're speaking of aftermarket stuff exclusively. With a stock tie-rod, you can only set the toe with the stock single tie-rod adjuster. You can't re-center the steering wheel this way.
But with aftermarket setups with either 2 adjusting sleeves and rod ends, AND/OR an adjustable tie-rod, you can "sometimes" re-center the wheel.
A single adjuster like on a stock tie-rod is not capable of centering the wheel. An adjustable drag-link's only purpose in life is to re-center the wheel.
Here's where I have to add: "At least not that I'm aware of!" ;)
bknbronco
North Metro, MN
Really why not? Isnt the point of centering the body over the tires? Who gives a shit if the frame is centered....I want my tires centered! And how the hell can the body shift? I call BS on the entire post!:p
I just run my broom handle up from the center on the tires, then measure the distance between the handle and the fender flare. Do the same to the other side and adjust the trac bar until its the numbers match. Run it up the center of the tire straight up off the ground so the numbers are taken to similar parts on the flares. The broom handle will touch the bottom and the top of te tire and give you a great reference point to measre the body centering over the axle.
