Front Suspension on a Stroppe Baja Bronco
Kandrews70
Does anyone know if Stroppe shortened the springs in the front suspension of the Baja Bronco? I noticed mine were mounted differently than most old Broncos I have had and they were cut shorter by about 2".
Thank you!
Kathy
Rustytruck
At the time I would suspect stroppe of using 1978 Bronco coils for their higher rating and cutting them to desired length.
KCSPONY
Newbie
it was common back in the day to order F-150 coils with the spring rate for a big block (360/390ci) motor, this gave a 1.5-2 lift, but was also a lot stiffer. Some cut the springs so they had the same height, but stiffer springs
Speedrdr
Not so wise OLD owl
Paris, MS
Stropp springs stiff?? That’s an understatement right there. I’m just gonna say that I ran over a fan belt n the street in a Stroppe special and it bounced me in the seat. Turned around and went back to see what I’d hit, fully expecting to see a dead dog laying there. Nope, only the fan belt. Stiffest suspension I’ve ever driven.
Randy
House
Minutia Militia
I don’t believe that Stroppe changed the front springs. Most of them were ordered from Ford with the U152 Heavy Duty springs with a 4900# GVW rating making them ride a little stiff…
Interested to see how they were mounted differently, that doesn’t sound like a Baja Bronco option either.
