hoooodini
I’m looking to do a full width axle swap on my 71. I found a 77 F250 with a D44 front and D60 rear. The rear swap is straight forward but I’m not so sure about the front. The 77 has leaf springs on the front and mounts for the shocks outside of leafs. Am I correct in thinking that I can cut off the perches for the leaf springs and the shock mounts and weld on wedges? It looks like the driver side leaf perch is partially integrated into the diff housing. If I remove these, can the wedges be placed in what would be the original location for an early Bronco?
Also, I believe the D44 is a high pinion. Will that fit a 71 with 3.5” SL and 1” BL?
