Full Width swap
TheBiologist
So I am putting full width axles under my bronco and had a few questions.
When installing the rear axle, do I just need to make sure the measurements from the new perch to the axle flange is the same on both sides? Also I have seen the pinion angle set both with weight on the axle and without, which is correct?
Apogee
Tangent, OR
Yes, the perches need to be centered on the housing, that way it will be centered under the rig. You should always set pinion angle at ride height, so while that can be a bit of a moving target depending on whether you're loaded or not, you just need to be close. I put mine close to 0 degrees (straight) now with a full tank of fuel, but intend to do a transmission/transfer case swap that will push it to about 1.5 degrees down in the hopefully near future. Having the pinion slightly low will allow for the bearing caps to rotate slightly and will account for some pinion rise under power if you're running leaf springs.
FWIW, pin to pin on my EB's leaf springs was 36" plus or minus 1/8".
Tobin
T
TheBiologist
I am running leafs but everything I have read say pinion angle between 5-7 degrees?
Then you're reading the wrong stuff!;);D
Nothing of the sort for our vehicles with double-cardan joints at the transfer case. Unless that 5-7 range is from some other reference point?
With a double-cardan/CV shaft and leaf springs like ours, you want the rear pinion pointed almost straight up into the shaft. Roughly 1-2 degrees down-bubble, like Tobin was saying.
This allows for pinion-climb in the form of axle-wrap/spring-wrap under acceleration, but it's not so much that you get a vibration under deceleration.
All done at ride height only, which is where angles are the most important.
Just out of curiosity, what have you been reading that stated 7 degrees was good? Perhaps a single-cardan shaft and the maximum degree variation the shaft can tolerate?
Oh, and if you don't want to wait for the springs to settle to their final height, or you're a long way away from having the whole truck back together (if this is a full restoration build) you can mimic the ride height by measuring between the top of the axle housing and the bottom of the frame rail and adding your lift spring rating to 6 inches.
So if you have a 3.5" lift, you'll set your frame-to-axle height at roughly 9.5" or so. There is some flexibility, but I would not vary that by more than 1/2" or so.
I don't believe there is any variation between this measurement with a Bronco housing and a full-size housing. The tube diameters were the same 3.25" and the perches should be well outside of the wider center section I think.
Ratchet straps make for some handy helping hands to compress the suspension.
T
TheBiologist
Thanks DirtDonk! I got 3.5 inch 11 pack leafs and got them compressed to 10 inches and pointed my pinion at my transfer case.
Now what is the standard method of attaching the new shock mounts? Do I compress the shocks any? How far away from the leaf plate should it be to maintain proper alignment?
Are the spring perches fully welded at this point, or just tacked? Remember we said a degree or two down from center, not straight up the driveshaft.
Now, if you're going to have some traction device to keep the leaf springs from twisting under acceleration, then straight up is usually fine. But without that, straight up into the driveshaft will often get you a small vibration when you're accelerating heavily.
More fun with the right foot will get you more vibrations!
Anyway, on the shock mounts you want to make sure everything on the axle is planned out. Such as brake lines and such. With the full-width scenario you don't need to worry about disc brake calipers or stuff like that, like we do with standard width. But it doesn't hurt to take all that stuff into account anyway.
Make sure you know for sure what shocks you will be using, because if you locate the mounts for a standard body shock and then go with some big fatties, you might find them trying to share space with the leaf springs.
Locating them downward (hanging down below the axle tube) is beneficial to helping reduce axle wrap, but you loose ground clearance. Moving it too far down and you run into shock body interference problems again, with the axle tube.
Are these mounts stock type, or custom?
If stock type, they're relatively short so I would bolt your shock-of-choice to the mount and locate it that way.
This way you can get both vertical orientation to avoid hitting the housing, and horizontal orientation to avoid the leaves.
I'm sure someone will have some other pointers, but those are the basics I can think of.
I know you asked for a "standard method" but not sure that exists in many areas of modification!
T
TheBiologist
I have detroit trutrac in the axle now so they are full welded. As for the shocks they are stock type from yall years ago. They are still bolted on top just need to figure out where to attach them to the axle. I am assuming that with the axle hanging on the leafs I want a certain amount of compression on the shocks to prevent any over extending or am I thinking about this wrong?
By traction device, I knew it was a vague statement and was trying to think of any word other than "traction bar" or the like. But that's what I meant. An anti-wrap device like our Wrap Trap, or the Duff Torque Tamer. Things like that.
You do like to keep the shocks somewhat in the middle of their travel, but you don't necessarily want to fine-tune the lengths by moving the lower mounts in or out on the tube. That just puts more stress on the fixed upper mount.
You could let it fall naturally, or you could move it up or down a bit, but overall that's not changing much over a 20+ inch shock.
My personal choice, unless I'm building a "most wheel travel possible" suspension is simply to put the suspension at ride height, set up the shocks so they clear things and are not binding, then tack weld the mount right there.
Then you cycle the suspension up and down to make sure that when it twists up the shock body is not hitting anything, and you're probably good.
If at that point the shock is either almost compressed, or almost extended, when it's in the neutral/ride height position, you probably just need a shock with a different length.
With the suspension still at that 10" point you had it for the initial welding, see where the shocks fall. It's very likely they're not going to be exactly half-way in their travel, and that's fine. They don't always fall perfectly in the middle.
There just has to be enough room to move in either direction.
