I think this is what your are asking for factory pedestal mount rockers to roller rockers
PRODUCT DESCRIPTION
Crane Cams 36655-16 Pedestal Mount to Stud Mount Rocker Arm Conversion Kit for 1979-95 Mustang 5.0L
This rocker arm conversion kit from Crane allow you to convert engines with pedestal-mount rocker arms into adjustable-type valvetrains, without machine work or cylinder head removal. It allows the use of 3/8" stud mount rocker arms. These kits allow standard pushrods to be retained, in most instances, as the guideplate uses a special composite insert that prevents metal-to-metal contact. Each of these kits includes guideplates, guideplate inserts, studs, a stud installation nut, and instructions. These kits are intended for mild performance applications using hydraulic lifter or hydraulic roller cams. They're not recommended for competition use.
