Had a strange electrical issue
ilovemaui
Pacific Moist West
To start, just about everything electical works on my EB except the temp gauge. The other day I started it up and noticed nothing on the dash or radio was working. No headlights, wipers, gas gauge, etc. The only things that were working were the alt gauge and the brake lights. I couldn't find any burnt fuses or any thing disconnected. The next time I started it, and ever since, everything works except the temp gauge. I'm thinking it could have been an ignition switch issue but was wondering if anyone else has had this happen? Fortunately it was daylight so I didn't need the lights but I'm a little concerned the gremlin could strike again when I do need the headlights.
Viperwolf1
electron whisperer
Definitely an ign sw problem. Temp gauge is not related. Check for loose wires at the gauge and sender.
oldiron
Agree with Viper. If the problem pops up again, try to turn on the heater blower motor, it probably won't work. Reach behind the dash and push the connector at the ign switch. I had the exact same problem last winter, this little test will confirm it.
Greg
