Phil76
Okay, I changed to a one wire alternator. I have one wire running from the alternator to the +side of the battery the way the manufacturer told me to do. The black/yellow wire coming out of the firewall I grounded since it was connected to the condensor grounded to the voltage regulator. The brown wire was then connected to the passenger side large post on the solenoid. Everything seemed to be okay until I noticed the connector going through the loop on the ammeter was disconnected. When I reconnected...smoke. Since then, when I turn the key to on, the parking lights go on. I've just done the headlight/parking light toggle switch conversion thinking it might have been in the old headlight switch, but I still have the problem. Do I have wires connected wrong somewhere, or is there a common wire on the ignition switch with the lights I need to check? Did I fry the internal voltage regulator on the alternator? I'm stumped. Thanks.
