Strange electrical issue
bnk70bronco
Redding, CA
None of my electirical stuff will work until the bronco actually starts and then everything works fine(wipers ect). Sometimes the key will switch the solenoid and sometimes i have to jump it with a wire. Sometimes is fires right up and other times it is completely dead.
I hooked up jumper cables and they heated up really quick and I wasn't even trying to start it. Then I disconnected the wires from the coil and the positive side wire from the pertronix lit me up like a christmas tree. So for some reason it is shorted across the pertronix. That might be the issue or just a symptom.
It seems to be something shorted out but I can't figure out what it could be.
My optima seems to have shorted out inside or something. It won't hold a charge anymore and the battery charger keeps shutting off and giving a fault signal. I hooked up a different battery and the truck still does the same thing though.
Any ideas?
RV77
Springfield,IL
Start by checking your starter.Disconnect the starter cable at starter and then hook up battery to see if the starter is shorting out.Good luck
00gyrhed
Some of your symptoms sound like a bad ignition switch. I have had problems with mine, but the charger indicating a fault indicates something else unless the switch is bad faulted and then you probably would have burned up the harness.
Have you tried to charge the battery with it disconnected from the bronco?
If it won't take a charge replace it, if it will then disconnect the alternator and see if every thing works, start it and run it without the alternator, see how it works.
airman
Is it a stock starter or one of the new er smaller Mustang starters?
There is a real good electrical trouble shooting format in the tech section. I'm not trying to dump you off here with a "do a search" answer either. I am pretty good electrically and I still like to read that once in a while.
The starter coil and the ignition coil both are powerd by the ignition switch. With the key off you should not have power to your ignition coil. Key at run you will. I would pull the ign switch and check its function or disfunction with a meter. Pull neg cable off of battery before pulling any parts.
bnk70bronco
bnk70bronco
Redding, CA
Thanks for the ideas. I originally thought it was the ignition switch as well so I replaced it but it didn't change any of the symptoms.
I also disconnected the battery and tried charging it but that didn't help. I am getting a new one today. It is still in its three year free replacement! WOHOO!
I am going to disconnect the started tonght. It has shorted out on me before.
I appreciate the help and I will check out the tech section as well.
bnk70bronco
bnk70bronco
Redding, CA
Figured out!!!
Gotta love it when it is something simple. It turned out to be the wire that hooks up the solenoid where the battery hooks up. Its the wire that sends power to the whole truck before it is running. Somehow it had shorted out so I replaced the connector and works like a champ.
Thanks for all the input.
