RedLeg0811
When I hook up the battery I hear a flasher going, it is the hazard flasher, but none of the turn signals are going. If I pull the harzards then the signals flash. If I push it back in the signals stops, but the flasher clicks again. If I move the signal cancel up it stops clicking and no signal. If I turn it down the right signal flashes. If I turn the key to the run position the right and left turn signals work. if I turn the cancel switch to the center I hear the hazard flasher clicking.
I hope that isn't to confusing?
So does anyone have an idea what I did wrong. It might be the GM blade hookup of Centech? The wiring schema for the harnes and the schema for the replacment signal cancel switch didn't line up.
Martin
Martin
