HEI Distributor questions
JWMcCrary
See the pics, this is what I have on this Bronco, 302 engine. Seems to work great, runs good. My question is how prone are failures? Do I need to carry some spares for it?
SteveL
Huge chevy guy
Hawthorne ca
I run the dui version in both broncos. After 18 years I had the module fail on the 66. Was thinking I should have a spare on the shelf.
Definitely!
And don't forget to put some thermal paste in the bag with it. They will fail quickly if not installed with a good dose of a heat transfer medium.
Regarding your initial question though, it can also depend on which brand you bought. The DUI is the originator of this GM/Ford-hybrid of parts, and were of high quality and price. The Chinese knockoffs that have been taking over were not so lucky.
At least initially, the failure rate seemed to be about 50% or more!
Haven't heard too many complain lately, so maybe the quality of the modules has gone up due to the failure rate of the early ones.
Hah! Kind of like GM experienced back in the '70's too. Can't tell you how many times I read about, or heard about someone's distributor module burning out prematurely.
That's why I wondered why all the fuss about Ford's TFI modules, when I heard of way more failures with the GM stuff. Just how it goes I guess. Different times...
Good luck. Hopefully you never have to use your spare. But you should have one for sure.
JWMcCrary
JWMcCrary
Are all modules the same? There is no brand name on this distributor anywhere that I can find. It was already installed when I bought it.
No, there are at least three, and possibly more styles of GM ICM (ignition control module) used in the various distributors within the line.
The aftermarket ones probably use the simplest one, which I think is a 4-pin style, and will have a specific pin layout.
With no brand name to call the manufacturer on, you will have to pop the cap off and take a look. Maybe get a photo of it and take that to the local parts store that can then set you up with the correct type.
Or if you're more of an online shopper, I'm sure there are pictures to compare yours to.
In fact, check out some of the websites for the known manufacturers, including DUI, Procomp, Summit, and even Pertronix in recent years. There's another one that I always get mixed up with Procomp (ProForm maybe?) that was also very popular.
We don't stock that particular Pertronix product, so don't have one to compare to. I'll see if I can find out though.
Obviously not all manufacturers have to pick the same module to base their unit around, but it's very likely they did just to keep things simple and inexpensive.
Just FYI as an option for a replacement module, Pertronix does list two, and possibly three appropriate GM HEI modules for these types of distributors.
Their D2000 is a replacement for a 4-pin module. Their D72000 is actually a replacement capable of multiple sparks, rev limiting duties, and probably a few other bells and whistles too.
If your distributor has one of the 7-pin modules (doubtful, but possible) the D2001 is the replacement for it.
The reason I think it's doubtful that the aftermarket uses the 7-pin units is that I believe (but don't know for a fact) that those were used with electronic timing control computers, or something like that.
Those are their own numbers too though, and don't list the GM equivalent for hunting one down at a local parts store.
But if the local computer has crossovers to Pertronix, they should be able to give you all the usual choices.
I would not cheap out though, even for a spare for the glove box. Or if you do insist on buying an inexpensive replacement, I would install it to make sure it works first. Then keep the old one as your spare.
Too many parts these days are bad right out of the box. Frankly then, it pays to verify that even an expensive one works before it goes in the glove-box!
MonsterBIlly
I have a Ebay DUI and it sucks. Well it did. The top kept popping off and one day when I was wheeling, the cap popped off and it damaged the rotor. I had to piece it together to get home.
Then, the coil failed. So I have replaced the module, cap, rotor, and coil. So I think it's good now.
Hazegray
I've had my Procompt HEI chinese knockoff running for over 12 years with no problems...sometimes I get lucky like that! :)
Wow BILLY, you ran into it all didn't you!
Glad you were clever and McGuyver-like too, or you might still be out there trying to get back. Posting to the forums can suck when you're channeling your hunter-gatherer self to stay alive.;D
lsukevinc
Holly Springs
i ran a summit brand for a few years without any trouble. It had the 4 pin module that could be found anywhere and the coil was available just about everywhere as well.
metal1
hidesert ,socal
ive been running the 49$ amazon model for about 2 plus yrs just recently installed all DUI internals because I had them as spares for my dirt track car would probably still be running the electronics from the original but now they are on the spare parts shelf .the funny part is they are not proud enough to put any type of marking of numbers on .but so far 20k miles on original ;)
ntsqd
heratic car camper
Upper SoKA
AFAIK the 7 pin and 8 pin HEI modules are for electronic timing controlled engines. That doesn't mean they can't be used stand-alone, but the dist.'s that they come in don't have mech. or vacuum advance so that rules that out. However, you can remote trigger them with a more typical inductive pulse type electronic ignition distributor. It is crucial that the pin that the OEM brown wire goes to remains disconnected from anything for this to work. I am doing this now with an 8 pin on my slant six '65 Valiant using a later Mopar electronic ign dist. to trigger it.
GM HEI's are power hogs. I've said it before but it bears repeating, draw relay switched power direct from the battery to run one of these. Your IGN switch won't be happy about the power flowing thru it. GM wired these with a 12 ga. power wire. I used fusible link wire between the battery and the relay.
Now think about where all of that power goes. It mostly gets turned into heat. That thermal conducting grease is CRUCIAL to the module's survival. Nothing else will work. I was late to work one day because I didn't have any and tried to use something else. Cooked that module, and it is mounted to a thick aluminum angle bracket that is bolted to the fender liner!
An 8 pin module in its native, no advance of any sort dist. in a non native engine; being mocked up in a slant 6 in prep for a complete TBI conversion:
