So my bronco has been sitting for 4-5 years.
Before it got stored in my garage, it ran just fine.
Previous to sitting her in the garage I had re-wired the entire bronco with a Ron Francis kit (I believe).
Regardless, it was performing fine.
I am moving in a month so I decided to get her breathing again so I started going through everything to try to get her started.
I wanted to start by just getting her to turn over.
Battery is good, solenoid clicks, but nothing happens at the starter. The starter was old, so I replaced it.
Still the same thing.
Curious thing were happening though, when I turned the key, there would be arcing through the stock throttle linkage. I'm talking about the stock throttle linkage that is hard mounted to the firewall and connects to the top of the intake.
I believe this is telling me that my ground between the chassis and the body is jacked up AND that my power lead from the solenoid to the starter is also possibly suspect.
Can anyone tell me what steps I should take to troubleshoot?
Please advise,
Chris
Please advise,
Chris
