akirshbom
- Feb 12, 2006
- 240
I hate to say it, but usually it's so obvious we never think to check. If things are getting as hot as you describe as quickly as you describe, my assumption would be you have a dead short. My guess is a ground somewhere on the battery side of the solenoid. Have you completely disconnected everything from the solenoid?
Once you have, connect the battery to one side and the starter to the other side, assuming you are running the stock bronco starter and not the late model mini starter. Then connect the start wire to the start post. Is it still grounding out the battery? When you turn the key starter should work, but truck should not start.
Ground is elsewhere, recheck every connection as you make them one by one to ident the circuit at fault.
