Help - Hydraulic Clutch Problems
jsander
Under your Bronco
I am currently running a Hydraulic Clutch set up the was installed by the PO. The current set up is pretty messed up and as a result I wore out the slave cylinder (external). I looked at going back to the stock linkage set up and don't think that it will work with the way my motor was installed, again PO converted to the 302 and the mounts set back about 2 1/2" too far.
I would like to stay with a Hydraulic Clutch set up and was wondering if any of the vendors sells a complete kit, i.e. master cylinder, line, slave cylinder.
Anyone got any ideas?
Desert Thrasher
What type of setup do you have now? I use all wilwood components and have been for years now. I had to rebuild my slave cylinder recently but thats the only problem I have had. I wrote a tech article about it, look in the Bronco Tech section of this site.
theshadow
I gotta say props to desert thrasher on that hydraulic-clutch linkage. I bought some BBK shortie headers thinkin that shorties would clear everything. WRONG! They ran smack into the mechanical clutch linkage so I had to rip it out and was totally sweating about how to set up a linkage. Then I read his article, ordered the parts, and a week later I was ripping! Use his article!
Desert Thrasher
Thanks guys. Im glad the article helped, I would like to point out that I have changed my rear mounting bracket in the tech article to a stronger bracket. I used a piece of 1/4" flat bar instead of the all-thread.
mag409
Central Pennsylvania
I used the tech article for the parts and made up a different mount. Machined a end and welded it to the clutch arm. Used 2" square .125" wall tubing for the rear mount.
jsander
jsander
Under your Bronco
Nice article D.T., it's nice to get some info on this set up. Everyone around here thinks I'm retarded for wanting to keep the Hydraulic Clutch set up, but just wait until they see what I come up with ;D Thanks for your help guys.
Mag ~ Thanks for the pic, that give me a good visual of what I want to end up with.
