Help needed! 66 Bronco Front hub issues
iguanaman1960
Nine Mile Falls, Wa
I'm trying to replace the front brakes and have ran into some removal issues. All my manuals, blogs read, this site and friends, still I'm having issues. Some help please? I believe it is the outer drive hub I'm trying to get off. Before I start hitting it with a BIG hammer, maybe someone can better guide me. It moves in and out some. Axle snap ring is out and outer ring as well. Trying to figure out how to post a picture?
Inner and outer snap rings both off, the guts should come out. Probably just need to tease it a bit. Try not to get it cocked and bound up.
For posting you either have to be a contributor, or upload images to a hosting site such as SuperMotors or PhotoBucket or similar, then post a link to the image.
For the hub, it sounds like you've got the main pieces that are required. Namely the two snap-rings.
Just to make sure though, are your locking hubs (lockouts) original to the 66? Did they have an flat faced center section of aluminum, with a simple raised ridge in the middle? Or were they something different?
If you are sure you got the only large ring out of there (a PO may have installed 2, but that would be pretty unusual I would think) and don't see any other possible impediments, maybe your splines are a little buggered or you just need to wobble the outer hub/drum assembly to allow the splined pieces to release.
They can be pretty hard to get out sometimes when the bearings are loose and things are floppy. And also when there is some rust or gouging on the edges of the splines of the outer hub.
Got most of the grease cleaned out of that front area so you can see better?
Good luck.
If you don't use the hosting sites, e-mail me any images you have and I can post them up for you.
73azbronco
on a 66 there can be a really fine round snap ring you don't see with all the grease about 1/2 inch inside the hub, it is round wire not flat like most and only about 1/16th round.
iguanaman1960
iguanaman1960
Nine Mile Falls, Wa
First off, Thanks guys for your response to my saga! So I checked all those possibilities out. Still nothing gives. The outer drive does move in and out about 1/4 ", but will not pull out all the way out. I looked for another snap ring that would be holding me up. Nothing!
Now the hub/selector to engage/disengage 4wd is a product of Sears! Go figure! Sears!
The selector had 6 screws in the cap. Cap off, engage/disengage collar off, tension spring off, snap ring axle off and flat type ring outer hub off. No room to use the axle nut tool yet.
Any other ideas or suggestions please!
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Turn the cap backwards, put the screws in from the backside and thread them back into the guts. Use the cap to pull the rest of the internals out.
73azbronco
Winner!!! Might also try some PB blaster and one more look to ensure the hub is round and not dented.
iguanaman1960
iguanaman1960
Nine Mile Falls, Wa
Thanks everyone! Finally won the battle! PB Blaster and some encouragement. Onward with the Bronco journey. Invaluable information on this site. Thanks again!
