Help Removing Horn Button
Dave K.
On my 74 I can turn the horn button so far and still can't remove it. It's hung up at one point--don't want to break anything. Okay, don't want to break anything further than seems to be broken already!
D
Dave K.
Image of horn button......
kip60
Mine has 2 ears on the plastic collar under the button. It twists counter clockwise and then comes off. The rotation isn't any more than an inch or so at the wheel end.
D
Dave K.
Thanks. I guess something went snap in there and is hanging it up. Just don't want to break anything on wheel. Will continue to putz with it...
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The plastic tab on the back of the horn button is a $12 part from any Bronco or Mustang parts house. If it's already broken, yank the rest of it off and replace it. It's a commonly broken part.
Pretty sure you have to push down on it before you turn. So obviously if your horn is working, it helps to disconnect the battery ground, like all the smart guys say.;D
Which is why I broke mine the last time I took it apart. It had been a long time since I'd done it, didn't bother to disconnect the power, and since I didn't want the horn to honk (naturally, right?) I just twisted it loose and broke everything all to heck.
So I say push in, turn it back to the right first maybe, then back to the left to see if it lets go.
Good luck.
D
Dave K.
Done pushed and twisted already but thanks. Guess I'll just pull it off and be done with it!
pcf_mark
If you are in a rush you can get one from a Pep Boys or AutoZone on a red Help! card. Once they get half off they can be tough to get back on or off because the tabs bind. I would actually try to push it back on and rotate it left and right to lock it back on. Then take it off in one smooth motion to unlock and remove.
D
Dave K.
Just broke it and was done with it. Onward with the disassembly, thanks all.
D
Dave K.
Okay, so the housing for the auto shifter stalk was worn at the roll-pin and I found in my stack of parts a housing without wear in the roll pin area, good and tight. However I noticed this bit of wear inside and wondering if I need a whole new housing or not?
D
Dave K.
Also pulled the stalk out and this is what it looked like (pardon picture quality):
