- Jul 31, 2001
- 8,977
Dang, the ONLY thing I barely touched in the ENTIRE 10 month build and it craps out on me!
I have made 3 trips to town as test drives since yesterday's first drive after a 10 month build. I pull up to the Post Office and it won't shift into reverse... Winters shifter is in R but I go FORWARD while the shifter handle is in the R gate.
I drive off and it's in limp mode it seems like. Won't go in any gear but 2nd.
Drive it home at 40 mph in 2nd for miles, tried putting it in N at a stop sign just to see what would happen and it went into 1st gear... made it home, pulled in the shop since I thought maybe my shift linkage was loose or had slipped-(really just hoping for something so simple)? I crawled underneath...nope-tight.
I checked the Baumann controller readout and P is P, R is R, N is N, etc as I move the Winters shifter so I know the range sensor is at least reading where the shifter is but WHY is it giving me these weird symptoms?
The readout on the controller I think said eR5...no such code but eRS is range sensor is bad... are these the symptoms?
Can't believe this...all I did was change the fluid, disconnect the linkage since I did internal KluneV work and replaced the Atlas with the 205... could a loose wire cause this code but I can't find a loose wire in the plug in connectors
