Help with brake and steering system design
markw
Calling out to the engineering minded members for help with this design.
What we have currently: 347 with Explorer serpentine system, stock Explorer steering pump, ram assist steering and anemic vacuum brake boost, 35" tires.
We would like to convert to Hydroboost. I have the parts for Astrovan, '78 Monarch, and SuperDuty HB units as well as WH canned ham conversion kit for the pump. We would like to use a Wilwood MC if possible. Mainly looking for advice on parts combination and a hydraulic line schematic. I haven't seen one yet with the ram assist plumbed in. This is a competition rig and it has to be a robust system. Thank you all in advance! Mark
StnePny
Santa Monica, Ca.
I would talk to Jason at TBM (The Brake Man )...they supply Gen Right Jeep that race KOH....
Tell him, Charles recommended them...
zacraig04
Memphis TN
OK. So I am a but confused with the supplied directions and how to connect this up. Take a look at the attached picture, what has me confused is the fact that one hose will go from pressure fitting on the "right" green cap to rubber hose @ the bottom of the reservoir?
And the other one will be pressure fitting on the "left" to pressure fitting @ the red cap on the stock pump.
Thanks ZC.
Ram assis is all down stream of the steering box.
Hydroboost is simply routed in line between the pump and the power steering box (with an extra bleed off line back to the resivor).
It's not that complicated. Just treat it as a normal hydroboost setup. Add 2 more lines from the box to the ram, just like any other ram assist.
The hydroboost adds no complexity to the ram assist.
The ram assist adds no complexity to the hydroboost.
M
markw
The more I thought about it the more I realized just what you are saying. Remaining question is pump capacity. Right now we have a stock Explorer pump. If that's sufficient we're good to go other than choosing our HB unit. I just don't know how much more demand combining ram assist and HB will place on the pump. Reliability is king. Thanks for responding! Mark
Hydroboost does not add any real demand to the pump.
Spec the pump to match the steering box and ram and you are good.
M
markw
Thank you BB. The ram steering has been working well for a couple of years. Time to put together the HB system. Thank you again!
rjrobin2002
all of them I have plumbed were the same. PS Pump high pressure port needs a HP line made to enter the single port side of the hydro boost, then the other side of hydro boost has 2 ports which is its exit side. Generally the larger inverted flare port on that 2 port side goes to steering box high pressure input side and the smaller of the 2 on the double side is a return to the PS reservoir. So now you have your hydroboost plumbed basically halfway between your PS pump and PS box. I have had the best luck using the Astro Hydro boost with the Astro MC and Astro proportioning valve all used together. It has perfect metering and proportioning for a disc front, drum rear bronco.
As Bowsher said, the ram assist is a self contained system where 2 ports are added to the PS box to send fluid to opposite sides of the ram. One line goes to one side of the ram and the other line goes to the opposite side of the ram and the steering fluid is sent to opposite sides of the ram causing it to hydraulically move.
rjrobin2002
West Texas Off Road and Lee's power steering are good sources for work on this stuff.
rjrobin2002
I would plumb it with the Explorer pump with the correct fitting and see how it feels before I upgraded. I have used the Explorer pump with a Astro hydroboost and 4x4x2 PS box with no problems and the Explorer pump with Astro hydroboost and stock Bronco PS box with no problem. I think Lee's Power steering can soup up your Explorer pump if needed. People have had fits with Explorer pumps not flowing enough when they don't use the Lee's PS adapter. I just bought a brand new stock Explorer HP line and had a line shop crimp the end on I needed to make it screw into my hydroboost metric bubble flare Astro input.
M
markw
rj, thank you for the additional information. The devil is in the details. Your detailed response is appreciated! Mark
ntsqd
heratic car camper
Upper SoKA
Some years ago when we were building the YJ from Hell we had Tom Lee do all of the steering stuff on the truck. He told us, in no uncertain words, not to use hose ends or adapters that looked like this:
We were to only EVER use hose ends that look like this:
