Help with hole in dash??
NGABronco
Always Learning
N. GA now South Carolina
OK Boys & Girls, it's a 74' Explorer "The Blue One". Everything I can find says the 3 holes should be ignition, brake light, cigar lighter. Thats all good except the 3rd hole ain't big enough for a cigar lighter?? It also has a rolled bump around it. Went back and looked at early pics and it had been used but nothing there when I got it. Any help!!!;D;D;D
fordfan
I bet the afterburner ignition switch was there, or the nitrous, or the air bag lowering control, or maybe even the Airguide compass mount.......:cool:
fordfan
Is the outer ring (outside the existing hole) large enough for a lighter socket?
kylakekevin
It says what it's for right above it. The wipe wash button goes there for when you ate mexican and drank to many Beers the night before!;D
spap
I had the ford factory ejection seat, didn’t work out so well with the hard top on, such a mess
Scoop
Bronco Old Fart
Cuchara, CO
Did you look behind it to see if it was welded in? (To confirm it's part of the original dash stamping.) Cigar lighter delete dash??
NGABronco
NGABronco
Always Learning
HaHa!!!
No PTO Keith!
No ejection seats!
Don't do Mexican & Beer (Tequila!!)
I'd need to drill it out for a lighter!
Appears to be original to dash Scoop!
Stretch is a 73' and the extra hole for the hazard got a red covered flip switch to "nothing"!!! may do the same here!!;D;D;D
spap
My 77 is ignition switch, brake warning light and cigar lighter
rguest3
The hole to the left is for the Brake Warning Light.
The hole to the right looks like the Cigar Lighter hole with a washer welded in it for the ???
wookie650
Like Scoop said, did you look behind the dash? Looks like a washer stuck inside a cigarette lighter.
NGABronco
NGABronco
Always Learning
No sir I've looked and felt it, smooth as a baby's bottom. I'm aware there should be a hole for a cigar lighter, but like Scoop said it would be a small one!!
Was the cigar lighter an option?? My Marti doesn't mention it??;D;D;D
fordfan
It was on a plain jane Bronco, but your Blue One is a Ranger......M Rangers had extras!....so it was included in the Ranger package. However, like Scoop mentioned, it may be listed as a optional 'mini' lighter....;D;D;D
JGbronc
Bronco Maniac
Hytop, Alabama
It's actually an Explorer, and oddly enough most of the Explorers I've come across didn't have one originally including my 76 and the 73. Dad has two Explorer parts trucks and I know one didn't either, possibly both.
