broncochevy
OK I know this question is been asked, some time has gone by and some different options are now available. I have a 67 bronco, power steering is going on it, I’m not sure what box to use. Obviously a no modify, direct bolt on sounds good, and with that said Toms Bronco parts box looks pretty Bitchin. It looks like the 4x4x2 boxes with Bronco bolt pattern. Price tag is kind a high though, and it seems like in all the threads I’ve read about power steering, there are many members supporting the 4x4x2 box. I see the pros for it, not really sure about all the cons except for it doesn’t directly bolt on. I realize there’s going to be steering shaft modifications, a pump that needs to be selected and installed, pulleys, belts, brackets etc. with all power steering conversions, but I would like a little more insight on what boxes are available; and the pros and cons of each. I don’t really want to hack up and weld all over my frame in the steering box location. I believe west coast broncos makes a 3/4” plate that bolts to the frame in existing steering box holes and has holes for the 4x4x2 box making it a little simpler to install. Also know about the xterra or Delphi box, not quite sure if they are the same or if the vendors version of the Delphi is a direct bolt on.
Tell me about all the options please, and the reasons why or why not to do them. Obviously the lower the cost the better, But I can spend money where it does need to go. This Bronco is not going to be a trail thrasher, but on the other hand it will see it’s fair share of four wheel drive use, steep roads, fire brakes, rocks etc. primarily a hunting rig driving to and from the hunting grounds. And when I say rocks I mean rocks on the road or trail and not solid steep Moab rocks.
Paul, I’m expecting a huge response from you here, LOL. Teach me!
