High Idle Headache
MerganserMaster
The idle on my 1975 Ford Bronco does not seem to want to go below 990 RPM, and I cannot seem to figure out why. For context, it is a '75 302 with a manual RAT transmission. The carburetor is a motorcraft 2100 (i believe) and no matter what I do the idle does not want to drop.
To set it up I first set the timing to about 10 degrees BTC (at engine operating temp), then I screwed in both fuel/air mixture screws all the way in and back out 1.5 times. After adjusting them so that I had 18 inch-lbs of vacuum (with no rise in RPM gained by moving them outwards) and turning the timing so that it was a few degrees closer to zero (~7 or 8 BTC) I got ~750 RPM and then I turned the engine off and put the air cleaner assembly and the vacuum line back on the distributor (which I had my gauge hooked up to). However, after starting the engine again and checking the RPM again, it read 1100 RPM and no matter what I have done since, it does not seem like it wants to go down again. I've checked for leaks around the carburetor gasket with carb fluid and have found none yet. I have the choke set open and the only vacuum line attached to it (running to the distributor) is free from cracks/damage (to my knowledge). The carburetor was rebuilt a couple of years ago and it hasn't been run that much (1000 miles at maximum). It does not appear that there is a "fast idle" screw wither on my carb that might be interfering with its operation.
My questions are:
What might be causing the RPM to be so high?
Is my timing messed up?
Do I need a new/different carburetor setup?
Below are a couple of photos of my carb:
https://flic.kr/p/2rci4yJ
https://flic.kr/p/2rchcfV
Speedrdr
Legend in my own mind
Paris, MS
Any chance there’s an issue with the electric choke that’s causing the fast idle problem? Or could it be there’s a bit of trash worked its way to the float and it’s causing the motor to burn more gas and at an elevated idle?
Just throwing it out there.
73azbronco
Dashpot sticking out to far? Not coming off fast idle cam lobe? could also be a vacuum leak.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
How many vacuum line connected to distributor?
If one line, it should be connected to ported vacuum source from distributor.
That is not manifold vacuum, which is what vacuum gauge should be connected to for adjusting carb.
If two vacuum lines connected to distributor, the ported vacuum from carb goes to advance diaphragm and manifold vacuum line goes to retard diaphragm.
MerganserMaster
MerganserMaster
I dont think the choke is the issue as it only keeps the choke closed when its cold out. I haven't cracked the carb open yet, but I wonder if the float not being set right could be an issue as that would explain why the idle is high (too much gas being let in to the carb) but that it runs/drives normally (float doesnt stay full)
MerganserMaster
MerganserMaster
besides the one vacuum line running off of the carb to the distributor, where else could the leak be? Most of the emissions stuff has been removed from this engine to my knowledge (unless the carbon canister is apart of the vacuum system). The vacuum line seems quite soft and flexible still so I dont think it is cracked
Ive set the dashpot so it just barely touches the throttle, if i have the throttle set too low then the engine dies for some reason as well, but from what I've read that is "normal" and is the reason why the dashpot exists.
MerganserMaster
MerganserMaster
There is only one vacuum fitting on the distributor (and the line is black with a yellow stripe), however, if there were an intake manifold fitting, where would that be? I wonder if there is an intake manifold fitting that is "unplugged" and contributing to the vaccum leak somehow
B RON CO
Statesville, NC
Hi, there are a bunch of things to look at. You have a spring attached that is pulling forward. That does not look right. Do you have enough slack in the bell crank (probably not the problem). Check that the vacuum advance diaphragm is not ruptured (probably not that). As mentioned, verify that the high idle cam is not touching the throttle. The choke can be fully open, and held open with spring pressure, like it is supposed to be, and the high idle linkage may still be engaged. As mentioned, you can loosen the dashpot, The idle set screw sets the idle. The dashpot is just a cushion, and you can back it off (probably not that). The PCV is also using vacuum, you can pinch off the large vacuum hose, and you can block the PCV valve with your thumb. Also, I never saw spark plug wires touching a carb, I would route them better. Good luck
Brush Hog
NorCal
I had same problem and finally found a small leak in my intake manifold gasket. So check for vacuum leaks all over.
MerganserMaster
MerganserMaster
That could be, i believe my intake leaks oil as well. I have a set of intake gaskets leftover from when was first working on it. Although I installed them on the engine, it never ran with them in and they have since been removed and kept in my tool chest. Do you think theyre still ok to use?
Brush Hog
NorCal
I wouldn’t. I had problems finding a decent gasket. Can’t remember if it was the fel pro or edelbrock gasket that was garbage. Installed one and it didn’t work so tried the other and no problems. I’ll try and find which one I used.
PNW
Never reuse those intake gaskets, and if you buy fell pro, make sure it has the steel insert. The non steel Felpros can cause hydrolock when they shrink, twist & deformed from the antifreeze & can allow coolant into your cylinder & cause hydrolock... I had this happen, checked with a bunch of SBF guys & it is a LOT more common than people think. I now use Cometic intake gaskets on my builds & have for decades.
If it idles no lower than 900 RPM, but then dies as soon as you turn it lower, something is definitely wrong
However, if you have to turn it way down before it dies, then yes, that is normal.
Your engine should idle as low as 450 RPM without a major issue.
Start with the basics. Turn your ignition timing back up to 10° before top dead center with the vacuum disconnected.
Screw the dash pot down and well away from the throttle linkage. Leave it out of the equation at this time.
Turn the idle speed screw counterclockwise with the engine idling and see how far down, or how well you can control the idle speed with just the screw.
If it’s already backed out and the idle doesn’t come below 900 RPM, then the only two (common) remaining things would be vacuum leaks, and the aforementioned fast idle cam not pulling off.
For vacuum leaks, spray some liquid all around the engine. Everywhere.
Normally, I use carburetor cleaner or brake cleaner because they’re very convenient. But since the paint on your engine looks relatively fresh, carburetor cleaner would be a bad idea.
Brake cleaner typically evaporates quick enough to not cause trouble with the paint. But don’t overdo it. You only need a little spritz here and there too see if anything changes.
Doesn’t matter whether the idle goes up, down, or just gets rough. If you spray it somewhere and the idle changes in any way, you have found a vacuum leak.
The fast idle cam issue is very common when carburetors get a little dirty pretty. Certainly after they get older like ours are now.
The only thing that puts the fast idle cam in a faster step is the choke spring. As the choke releases, only gravity pulls the fast idle cam back down to its normal setting.
If you can’t see back there without removing the carburetor, don’t do so just yet. First thing I would do no matter what, would be to spray carburetor cleaner all around the choke linkage behind the choke spring housing. Then lubricate it.
I know your carburetor is not that dirty, but a little cleaning is a good first start. Then afterwards spray a light lubricant such as WD-40 in there. It’s not a permanent fix, but it’ll let you know pretty quickly if the fast idle cam was sticking. If it’s seriously sticking, then this won’t work. But I haven’t seen one do that in a long time.
Usually, it’s just a little stiction keeping it from releasing.
By the way… How long has it been doing this? When did it start under what circumstances?
Did it come on slowly, or all at once?
MerganserMaster
MerganserMaster
Its been like this for a while, also I believe that after reading this thread and messing around more the leak is in the drivers side pcv valve as when i plugged up the line the rpms are now normal (first in the 550s range but now ive raised them to the 750s).
Additionally, i found that my voltmeter/tachometer reads a higher rpm if you measure the "back" of the ignition coil wire versus the "front" (where the wire plugs into the "socket"), i wonder if this could be contributing to the problem (although it seems bizarre considering the "current" that is being detected should be the same on either side of the connector).
Upon further tinkering it seems that the reason it "dies" when its below 900 rpm or so is that I have completely starved the engine of air by completing closing the throttle. After plugging the pcv intake thingy on the bottom of the carburetor manifold the engine is now "behaving" so i think I will have to pick up a new breather cap/pcv valve combo with a vacuum line to match. Right now I have an old-school breather cap on the valve cover and a screw plugging the vacant line.
Interesting. Still doesn’t sound normal. Any chance you can take some pictures to show us?
You can post them up in your “garage” or “gallery” functions above. Or use an image hosting site and post a link here. Or you can also send them to me at Paulb@wildhorses4x4.com.
Ultimately, it’s easiest to upload them directly, but for that you have to become a contributor for $12 a year. If you want to do that right away, it’s a great help for the site. If you’re not ready to throw money at a forum, that’s totally understandable.
Might be something we can see that stands out as a potential issue.
PNW
$12 IS a cheap fix tho... :)
Someone here will figure it out... could be a host of things but I'm sure it is a simple, overlooked thing. Go thru Paul's list and let us know and we'll keep digging deeper.
Slowleak
Georgia
A 75 Bronco should have a 2150 carb which has the ported vacuum port under the choke on the right side. In your photo that port appears to be capped. You are running full manifold vacuum to your vacuum advance which explains why your vacuum gauge, when connected to the hose, is showing vacuum at idle. You are getting spark advance at idle with that hose connected to the vacuum can. That’s why your rpm increases when you hook the hose to the can on the distributor.
Hook that hose to the ported vacuum port. It is currently hooked to the choke pulldown port which is full manifold vacuum. Just swap the hose and the cap in the photo below.
MerganserMaster
MerganserMaster
I don't have any pictures right now, but I think the problem may be related to the fact that the connections on the ignition coil are crusty and that may interfere with how my tachometer/voltmeter reads the rpm. One day Ill become a contributor for this site, most likely once I get more time to work on my bronco
