HiPo exhaust clearance problem
wyattja
So I got some HiPo exhaust manifolds for my 74 Bronco with a 302 and i'm having clearance problems with the exhaust port and my zbar bracket, has anyone found a remedy for this or am i going to have to swap it our for stock headers or manifolds?
BTbronco
I don't think there is anything you can do but swap to a header that fits.
jckkys
The HiPo 289 Mustangs were nearly all 4 speed cars, so they must have had mechanical clutch linkages that work with the HiPo manifolds. I seem to remember a different equalizer bar for HiPo cars. Check with one of the early Mustang sights or forums.
W
wyattja
Lucky for me my dad has a K-code I've looked at, but the clutch fork/bellhousing isn't the same so I'm not sure it'd work, I might just borrow his and check though. I have the original manifolds if all else fails.
What's the aluminum bell housing from? Is it the larger truck size to fit the big clutch?
Yeah, but what was the original application? Do you know if it came from a particular truck model or car? Older or newer? That kind of stuff.
Part number visible anywhere?
paul
