Thats the tall dual plane intake there are shorter ones. there are also drop base aircleadners and thinner filters for the air cleaners. the stock cast iron four barrels are a lot lower and Edelebrock sp2p I believe are lower as are the performer line
I personally uses the cast Iron 4 barrel, a spacer Adapter, a Quadrajet carb and a 14 inch drop base air cleaner with a flat top and a low profile Wix filter which is about 1-5/8" tall under the stock hood with factory motor mounts and worn Factory body mounts.
