- Jun 1, 2007
- 363
The dry sump is for the 7.3L Godzilla. I’m not sure if it will clear stroker cranks because I haven’t seen any for the Godzilla yet. I haven’t looked into a dry sump for a 351W.
The 30HP loss was from an estimate I ran on a flywheel calculator I found. I just treated the adapter as a heavier flywheel. I’m pulling from memory, but I believe at 2,000 RPM the loss was less than 5HP, but at 4,000 or 5,000 RPM it was more like 25-30HP. Of course you’re not losing anything from maintaining speed, just from when you try to accelerate.
At some point I thought about doing a hand built frame, but I honestly wasn’t very excited about it. I think it started to feel more like I was building a buggy than a Bronco. I find it more exciting to see what I can fit inside the existing frame, so that’s what I’m going to do. Though I reserve the right to change my mind (wouldn’t be the first time).
