Green-red at the regulator is the same as the run on the back of the ignition switch that the ballast wire is attached to. Often hot in start, but not always. I've had it where it was hot 98% of the time, but every once in a while it wasn't. Depended on what mood the switch was in at the moment.
What do you need the hot in start and run for? EFI? Are you deleting the stock ignition and ballast wire? If so pull the "I" wire off the starter solenoid. Splice the Green-red to the "I" post on the solenoid. The "I" (ignition) on the solenoid will keep the run wire hot while in crank even if the switch is a little flaky.
