- Aug 27, 2001
- 5,151
71 Bronco stock 302 (changed to electronic ignition) professionally cleaned and rebuilt Motorcraft 2100....starts great when cold. Drives good. Cut it of and turn the key and it starts back up perfectly......Cut it off for a couple of minutes and turn the key and it fires right up. But.....If you wait 15 to 30 minutes and then try to start it...it sounds flooded so you have to push the gas pedal to the floor,hold it 2-3 seconds and then it'll start. That's the only way I have found I can start it after engine is warmed up and u cut it off for a bit then try to restart it. How can I get it to start every time no matter if hot or cold, and no matter how long I let it set before restarting ?
Blue71
Blue71
