Hot Start question
livndlife
Hello all. Well last week I was having problems with very high RPM on cold start and I was able to solve that problem by adjusting my high idle. Now everything looks good once everything starts up. And once it's warmed up, choke is fully open and idles great. But when I turn it off, and if I wait a couple/few minutes for example, and do a hot start, it seems to be struggling. It does start up but then I have to rev the engine (usually just once maybe twice) to keep it from dying. What should be my initial adjustment for a hot start so that it starts right up without revving? Thank you in advance.
jckkys
You may be giving it too much accelerator flooding the engine. I just turn the key THEN just touch the accelerator. The engine doesn't need a big shot of fuel when it's warm.
livndlife
livndlife
jckkys. Sorry I guess I wasn't clear on my post. What I meant was, on hot start, I do not even press on the accelerator. And when I turn the key it struggles to start. It does turn over but to a point where it will almost die after starting. This is when I press on the accelerator so it will not die. My question was, what carb adjustment do I do to address the struggling at hot start? I agree, I should not even be pressing the accelerator once it reaches idle temp.
IT could be a bunch of things. Is it dying from being too rich, or too lean? I am guessing too rich, but that is a wild guess.
The first thing I would check is timing, is that set right? If the idle mix screws are set correctly (after the timing is set with a timing light, not by ear or feel) and it is still doing it my next item to check would be the float level. I am guessing too high and it drools some gas into the engine giving a mild flooded hot start.
jckkys
AFBs are aren't going to leak fuel while just sitting. Any fuel in the float bowls has to be lifted over the top to go in the intake. Either the float bowl is over filling after the engine is shut down or the accelerator pump is adding excess fuel. Leaky gaskets or diaphragms can't flood the engine like Holleys or Ford carburetors. Look down the throttle bores after shut down and see where any fuel is comming from.
A more advanced initial timing will help idle. Try 12 degrees. That's only 6 more than spec. I've never seen a Ford engine that didn't benifit from that. After all, if you get pre-ignition under a load you can retard it a little till the pre-ignition goes away.
70_Steve
Old Guy
My thought is that it's not fuel leaking, but fuel evaporating in the fuel bowls, and the vapor going down the venturies, creating a rich condition on hot start. Try putting a phenolic spacer between the carb and manifold, to try to keep a little heat away from the carb. That worked (some) for me.
livndlife
livndlife
Thanks all for the feedback. I think I have a list now to pursue.
If I missed an item, please let me know.
(1) Will verify timing. Was just done recently
(2) Perform float adjustment
(3) Verify float drop
jckkys
I have some of heat soak slow starting in the summer but not now when it's only in the 80s. When it does happen in 100+ weather, a second or two cranking clears the vapor. When the engine starts it runs and idles smooth immediately. My AFB is from the 60s and has no vapor recovery or bowl vents to the atmosphere. There must be something else going on.
ntsqd
heratic car camper
Upper SoKA
All carbs have bowl vents to the inside of the air filter area. My 70's era AFB on my Ranchero's 302 would hot soak and be hard to re-start after a hot shut-down if it didn't sit overnight. Insulating spacers helped a little, but not a lot. What nearly cured it was a DZ302-like insulator plate under the carb. I built mine from 1/8" aluminum sheet metal to be nearly the length of the intake and every bit as wide as it. That kept the heat that was radiating up off the engine from soaking into the bottom of the fuel bowls.
