Today I started having an intermittent ignition problem. Stock 302 with battery coil ignition. Still using points. Cuts out for a few seconds then starts running normally again. Got back to the garage before I could try to diagnose anything.
I'm thinking maybe bad ignition switch or a wiring problem, but who knows?
Before I head off down the road again, I stuck a couple jumper wires in the glovebox, hopefully to keep myself from being stranded.
If I remember correctly, if I run a wire from the hot side of the battery to the positive terminal of the coil, that's all I should need to keep the battery-coil-points ignition working?
Can someone refresh my memory?
