Brad H
Hey All,
Installing one of the vendor’s power steering conversion kits.
While installing my drop pitman arm on the steering box shaft it doesn’t appear to want to slide up any further on shaft while I tighten the lock washer and nut with a large breaker bar. When I take the lock washer and nut off and look at the bottom of the pitman arm the splines are not flush with the bottom of the pitman arm. My torque wrench clicks at 60 ft/lbs at its current position.
Would feel better if all splines were engaged in the pitman arm. What has been your experience? Should I try and tighten the nut more in an attempt to get the pitman arm further up on the shaft and fully engaged with the splines? Or is this normal for these conversion kits?
Thanks for any advice.
