MyBronco15
I got my 71 a couple years ago and slowly have been fixing what doesn't work.
Well, it never ran very strong but started easily, idle was smooth, responsive throttle as long as no load. Also wouldnt come to temp. So i cleaned and flushed coolant, added thermostat (po ran without with none) Advance timing to around 12 degrees. Ran much better until it got hot and bogged down. Pulled a couple plugs and they were black as coal so i Leaned out the Carb, ran again and felt much better but seems to be missing a lot, fishbites and fluctuating idle. Pulled plugs after running a bit and black is starting to burn off but still look almost new. cleaning those up now, checking gap and reinstalling but what should be done for ignition system? Plug wires did bite me a bit when i was tuning so was gonna replace those but seems like more. Also when I was setting timing was using vacuum and light but it didnt seem to work exactly like i expected. Engine would run rough around 4 btdc but never really ran rough the other direction. I maxed out where vacuum hit fuel line to carb. Any thoughts? Contemplating duraspark but still think this should be something simple. Should I just replace wires cap and rotor and see what happens even though they all look good?
