Delbert
Hi all. After searching thread after thread I can see there are some very smart people here but I still can't figure out my problem. Last weekend my 69 quit on me a mile or two from home after wheeling hundreds of miles with no problems. No spark to plugs. I replaced the ignition switch, coil and even the starter relay with no change. I had a mallory point eliminator kit that I installed probably 10 years ago I figured was the problem. I could not find a replacement so I went with the Accel point eliminator kit....It was the fastest available. I also purchased the wire set that was recommended, a non copper core as well as a matching coil. I installed it today and it started up right away and ran perfect. I was happy! I shut it down to clean up my tools and 30 minutes later go figure it wont start now. Starter turns over fine and it has gas, Just no spark. I don't know crap about electrical. With ignition on I got juice to the pos side of coil but none on neg side. I am using a ballast resistor and have juice to and from it. I'm wondering if it's the point eliminator kit and if so what could be causing it to go bad that fast. I'm about to give up. Is it something obvious? Anyone else experience this?
