tmorris1076
- Joined
- Mar 21, 2013
- Messages
- 66
Got in my 73 yesterday and it would not crank or even barely turn over. Tried jumping it to no avail. Tested battery and it had 100% charge. I then switched out the starter solenoid and it cranked right up. Old solenoid below
When I went to shut off the truck engine kept running. All electrical was off with key in the off position but engine continued to run.
Do you think this is a bad starter solenoid or bad ignition switch? What should I check first?
I appreciate the help,
Tyler
Tyler
