Interior Light in Top
74 Bronco Billy
Did Bronco come with an interior Dome light with spots? This picture shows one that looks period correct? If not, do you think it is from a new full size Bronco? I'm thinking of duplicating the look, but haven't found any new products that look similar. I personally prefer LED, so I could change out old bulbs and go to LED. Got any ideas?
blubuckaroo
Grease Monkey
Ridgefield WA
A dome light was never an option.
I installed an RV style light mounted to the head liner.
I later wired it to door switches when I needed them for the alarm system.
bigmuddy
Marthasville Missouri
Those used to be an aftermarket item sold by many places. I know JC Whitney catalogs had them.
Might have also been a repurposed old custom van piece too.
jckkys
That dome light was common in '70s Ford/Mercury cars and trucks. I like them. They weren't offered in EBs that had a light in the wiper motor cover. They were period correct tho. Ford didn't see Broncos as much more than farm implements, so niceties like good interior lighting got left out of Broncos.
74 Bronco Billy
74 Bronco Billy
So look at 70s fords for the dome light, got it. What about door lights, any ideas there?
Sent from my SAMSUNG-SM-G930A using Tapatalk
onpier55
Roseville Ca
Let me know if you want to know the part numbers.
ared77
Let there be light!
Wow onpier55, that's impressive!
Steve83
That chrome dome lamp with map lights was used in many Ford/L/M products including F-series & Broncos through '94 (maybe even up to '96). It's a poor dome lamp due to the milky main lens that yellows & becomes brittle. The later plastic dome (from ~'92 in Fs/Broncos continuing through maybe '04) was also common (especially in Tauruses) but has a superior clear lens, and can be had in several matched colors.
(phone app link)
(phone app link)
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
I installed dome lights on the roll bar activated by door switches many, many years ago. It has always worked well. But I could use an LED upgrade though.
sk1nw4lk3r
If you're after one like you have in your photo, I may have one I'd sell you pretty cheap.
I have used https://www.amazon.com/SUPERNIGHT-T...50+Waterproof&qid=1558194806&s=gateway&sr=8-5 and it is holding up great years later. I have some under a bridge in the back yard, the original sticky tape is junk but the light themselves are great.
If they are too bright I have used the sub $10 dimmer to dial them back. A too bright LED backed down will last way longer than a too dim LED being overdriven.
I like the effect of the light on top of the roll bar. I would just need a clean headliner to pull that off.
jckkys
If you want a really bright interior light, find a '90s Crown Vic police car in the junk yard. They have a switch operated round light behind the rear view mirror that's about 150w.
Scoop
Bronco Old Fart
Cuchara, CO
The Bronco "dome" light is in the windshield wiper cover - started in mid-69 with the switch to electric wipers.
