Is my bronco overheating?
flexmerc
My bronco when I bought it has a elderbrock intake and 4bl carb, maybe a crankshaft upgrade (mechanics think so), log tube headers and a aluminum radiator.
I notice that the mechanical fan didn't have a shroud so I decide to purchase the following from wild horses:
Flowkool water pump
Ron Davis 180 thermostat
New thermostat housing
New rad hoses and heater hoses
Ron Davis full fan shroud
New water temp sensor
The "problem" is even at prolong idle the temps get upward to 230.
What am I doing wrong?
spap
Go to harbor freight and get a handheld laser thermometer and check it. could be the gauge or the new temp sending unit isn't the same ohm s.
Does it smell hot. You can tell when something is at 230 compared to 190/200
Plus all of the above
flexmerc
flexmerc
good idea with the laser
Need to burp it
Sending unit is from wildhorses....?
and how do you know which way is the correct way?
It doesn't seem hot or burning, but feels warm
Rustytruck
Do you have a stock type fan with 7 blades on it? Thats the best one Ford made for the Bronco. Is the fan 1/2 to 2/3 way into the fan shroud and no more than a inch from the tip of the fan to the sides of the hole in the shroud?
Slowleak
Georgia
The fan should look something like this when installed correctly. Looking at it from the front, it rotates clockwise.
gr8scott
\and how do you know which way is the correct way?
The smooth side of the fan rivets should face the radiator, like in slowleak's picture.
EDIT: Here's another view:
flexmerc
flexmerc
With the new ron Davis full shroud I had to have the mech trim the enclosure, roughly 1/2 of the fan is out. I have a aftermarket 6 blade fan it looks like a flex a lite.
I only have about half a inch from the current da blade to the AC compressor, there isn't a lot of room.
Rustytruck
Is your radiator full to the top and are you using a coolant recovery system? If you take your hot engine at idle pushing 230 f and run it down the freeway does the engine cool down to thermostat temperature.
? If it does then you have an airflow problem or coolant flow problem or a combination of the 2. Not a radiator problem. Are you using a proper coolant mixture and not strait antifreeze?
flexmerc
flexmerc
50/50 mix, I want to run less coolent and more water, 30/70?
When you run it at high way speeds it cools down to thermo temps
I'm running a coolent recovery system
Rustytruck
That means your radiator is big enough and able to cool the truck when making power.
What about engine tune? You have headers and a possible cam change, so your intake fuel/air mix needs to be corrected for that as well.
Are you carbureted with the Edelbrock still? If so, do you know if it was ever tuned or if it's right out of the box?
What about an extremely important aspect of engine cooling... As in ignition timing? If you're too retarded (and maybe even too advanced sometimes) your engine will build more heat than most systems can remove. Your system is, or should be, more than sufficient to cool a normal engine.
Is your engine equipped with a functioning PCV valve system?
Just a few more questions to dwell on to see if we can narrow this down.
Good luck.
Oh, and definitely verify that your gauge is reading correctly. Very important first step I'd say.
blubuckaroo
Grease Monkey
Ridgefield WA
flexmerc, how about a photo of the fan/A/C, and a better description of your car's options?
Is it auto trans?
bronconut73
1) Fill your signature line up with your vitals.
See mine below.
It helps folks help me, since they can see what I have at a glance.
2) Post some photos. We love photos. If you haven't already, you may need to be a contributor to upload photos. It is sooo worth it.
flexmerc
flexmerc
Is it auto trans?
All, I will update my profile, my apologies.....
Ive attached some photos of the fan, the spacing...the whole cooling setup and the headers that came with the bronco from the PO.
I have not had the bronco Timing and carb tuned professionally.
The bronco is a auto trans, and has a AC cooling radiator in front of the engine rad.
Looks like you have the common Bronco dilemma of no space to work with.
You have a spacer between the fan and pulley you could remove, but then it looks like the back edges of the blades would hit something or another.
If you still want to gain some space at the radiator core (and it looks like it would be beneficial to do that) you could use a thinner spacer or machine that one down a bit. Just measure how much space you have to work with before it hits something, and machine it down only enough to get the job done without hitting.
If that's possible.
Looks like it could be done from here, but maybe the angles of the pics are hiding something that's already just too close.
If that's the case then you either have to live with the positioning of the fan, or push the radiator/condenser further forward. Not a simple task either, as you can imagine.
sykanr0ng
Maybe it's the radiator but that fan looks tiny to me. What's the diameter?
/\/\ That +1
The fan shroud opening should be only a little larger than the fan, just enough to keep them from hitting if the body or engine twists in its mounting.
The purpose is to pull the air through the radiator, not allowing it to leak around gaps.
