- Joined
- Sep 20, 2018
- Messages
- 353
Couple questions, trying to do a thorough cleaning/inspection
of front and rear axle.
Front- Just removed the cover off dana 44, this is what the inside looked like. Is it normal to have this rust inside? It's also on the top half of the inside cover. I tried cleaning it but seems not to come off.
I have seen different opinions on gasket only, no gasket just rtv (black some say only use gray, and I have also seen use both gasket and rtv), what is the census here, what has worked best for you? What's the torque on these?
Rear- (Ford 9") confirming to change the gasket you have to remove the (3rd member), should this just slide out smoothly or are there more steps to remove it how about reinstalling it? Same question as above for gasket? I also read that there should be copper washers underneath the nuts for the 3rd member, mine do not have any ( not saying they never did, they may have before when I got work done to it, but there not there now, should I get some before reinstalling? It also says these are torqued 30-35 ft-lbs, is that right?
If I missed something please let me know.
Thank you in advance for your time/help,
Sonny
Sonny
