Is this too short ?
JWMcCrary
I already know the answer and crap this will make the 3rd time to get it right.
It has about 1.5 inches before the splines start showing. I don't have any way of flexing to check it and I suppose there is no way to know whether I can get away with otherwise. Educated guess, what do you think?
bknbronco
North Metro, MN
looks good to me. It don't really extend as much as youd think. Run it until it poses a problem then switch to a long spline shaft
shamu
Lucky as the day is long.
Sachse,Tx
If you have an engine hoist near by pick up on the drivers side (bumper) as far out board as you can and lift it till the front drivers side tire comes off the ground. You should be fine for what I see.
Have a great day and see you in October?
Tedster100
Chairman of the Bored
That looks familiar.... looks like it will work. x2 on lifting & flexing to check. Had both my shafts modified when I put the ZF in and the rear ended up about 1-1/2 too short. Went to get it re-tubed to fix and they had a longer yoke for half what the re-tube would have been. Might be an option if it's still too short since you went to the same place.
