Just a couple more C4 swap questions
Tgirouard
San Diego
The home stretch is here. I am hooking up the plumbing to my C4. I have a few already bent lines that came witht he tranny. I am having trouble figuring out how they fit.
1. Can i run flexible hose for this to make it easier? Do they sell braided lines?
2. Can I hook the vacuum hose to any manifold vacuum?
Thank you for all your help. I don't know what I would have done without this site.
TexasBronco
Waterford, MI
Many c4 had no lines, so i found little 4 inch sections of pipe that fit each hole and ran soft rubber lines all the way to the cooler and back. You can call some speed shops and find some generic braided lines that run the distance you need. the vac line can be hooked to any manifold port, just not to the carb.
