EFI Problem..Update, Couple More Issues!
BroncoBrummet
BroncoBrummet
Spring Creek , NV
ECM disconnected, same thing. IM going to tear into the harness and rebuild as needed this is twice now Ive had something wrong in there. I had Kolibar rebuild it but having alot of issues. There is only 3 wires from TFI to the ECM correct? Ill fix once and for all. Sound like a good plan?
BroncoBrummet
BroncoBrummet
Spring Creek , NV
Just to be completely clear what do you mean? I think I will just run a new circuit for the 3 wires in the shielded wire since thats where im having problems. I will run a ground "wrap" on it then shield it with the tinfoil correct? I will still check everything else but a good start huh?
BroncoBrummet
BroncoBrummet
Spring Creek , NV
Found the bad spot in the harness. Inside Alum sheilding all 3 wires in there had a spot with cut insulation and making contact with the ground. Rebuilding that whole circuit today and then should have her running again this afternoon.
