First post here. Had my bronco for less than a month and already broke something.
I took my 73 to a mud pit and after getting stuck in some thick mud broke the transfer case. the teeth are striped off the slider gears
and it only works in 4h and 2h so obviously they need to be replaced. I understand I could replace them with the original gears and should have no problem doing the work myself as I have a press. Where could I get a set of sliding gears new or used?
Background on the rig
Mild 302
Twin stick dana 20 (former j shift)
5.29 axles, np435 39.5 tires
Full width 9 inch and 44 front
arbs front and rear
I don't know if the reason the gears broke was my wheeling inexperience, the gearing not being low enough or just the dana 20 two weak for my setup.
Which leads to my next question. Is a low 20 kit a good idea?(anyone know where the best deal on the low 20 kit is?). Or I should I try the JP eaters 4.86 gears depending on the price.
I would love to just spend the money and get an atlas or stak but I don't have the time to do the installation it requires.
Opinions on what I did wrong? What I should replace it with so it does not happen again and where I should get my parts?
Thanks for any input to a EB newbie
Mild 302
arbs front and rear
