Left me stranded - charging system question
pcf_mark
My second test drive and I had to take it to work! Coming home in the dark it stalled. I assume because it was still cold and the choke is not dialed in. When I came to rest it would not crank. Not even a click. I had power for lights and 4 way flashers.
I jumped it several times with another car and it cranked but would not start because I could not crank it quick enough. After really letting it soak up a good charge I did get it to start. I have a volt meter installed and it usually reads around 11- 12 volts. Once it was started the volt meter was reading 8-9 volts. While the engine was running it would spike up to 14 - 16 volts for a second and load the engine down like I turned on A/C. Only for a second and it would drop back down to 8-9 volts. It did this several times and finally the engine stalled.
The battery, alternator and regulator are less than a year old. My first thought was the starter was bad and drawing a huge amount of current to start. But once I saw the volt meter act up I am suspicious the charging circuit is not so good and the battery was going dead while I was driving.
Any suggestions? It has some electrical gremlins but I have let it sit a week and had it start right up.
oleguy74
calif city ca
lets start fresh,load test battery.clean terminals and cable ends.put some terminal grease on batt posts.make sure batt is charged.re connect cables and make sure they are makeing good connection.with a volt-ohmmeter check voltage.try to start.when it starts put voltohmmeter on battery,should be 13-14.5 volts.OH before you connect battery cables,make sure voltage reg is tight and grounded.then connect cables to battery and try.
ochretoe
Millington
Mine did the same thing and it was my ground cable. It had burnt in two but the plastic coating hid the burn. Set up a temp ground and see what the meter tells you.
broncnaz
X2 on checking the grounds and cleaning the main connections. Charge up that battery and take the truck to a parts store where they can test your system. That will tell you if the charging system is good or not.
If the charging system checks out then I think you have something pulling current that shouldnt be. Bad wire somewhere maybe.
Revelation
If you are running a 3G alt, run a ground wire from the alt. to a good ground. I don't think you have to ask how I know this one.
Steve83
This strongly suggests a loose or VERY bad connection. Read these captions:
pcf_mark
pcf_mark
I charged the battery over night and it started up no problem. Volt meter reads a steady 10-11 when running with parking lights on at idle. I am going to clean, tighten each connection. Then I am going to check the voltage at battery, alt and regulator.
One odd item. The car has a stink to it like I spilled the battery acid. I was wondering if the regulator stuck and cooked the battery a bit? Now that it is charged it seems ok. I don't trust it and need to sort it out.
pcf_mark
pcf_mark
Thanks guys. I cleaned the terminals and charged the battery. Then I took a series of reading as shown below.
Key off:
Across posts on battery: 12.65 volts
dual orange or yellow at regulator: 10.00
green at regulator: 0
red at regulator:0
Key on engine off:
Across posts on battery: 12.57 volts
dual orange or yellow at regulator: 12.46
green at regulator: 12.15
red at regulator:12.3
Key on engine running:
Across posts on battery: 12.25 volts
dual orange or yellow at regulator: 12.32
green at regulator: 11.45
red at regulator:12.10
From hot post on alternator to ground at case: 11.83
From hot post on alternator to ground at battery: 11.88
Because the voltage at the alternator and at the battery are so close I do not think I have a wiring problem on the charging circuit (maybe on the regulator side)
How do I "full field" the regulator to see if I can trick the alternator into charging to determine if the alternator or the regulator is the cause?
Thanks!
oldiron
Do a search for "full field test" on google. There are several good articles on this one.
Greg
What alternator are you running? Different techniques for different alternators.
Or the easy one, take it to a parts store and have it checked. Just because it is new doesn't mean it is good.
u10072
Two things that make the EB dependable are the 3G alternator and heavy 2-4 gauge battery cables. The wiring is stupid simple and the heavy cable simply conducts the electricity so much better. Forget all the factory wiring nonsense--- if there is a charging issue with the 3G its the regulator as the golden rule. Do yourself a favor and make the very simple upgrade.
RRRAAAYYY2
Brantford, Ontario
For the small body: Unplug the regulator, take a small wire from the positive post to the post with an orange insulator under it, right beside the positive post and the rear bearing. Just tap ity, you should see a small blue spark and the engine will slow down slightly.
pcf_mark
pcf_mark
I believe it is a stock rebuilt unit. Not sure because it was put on right before I got it. It is in an odd bracket - one that has an extra position for another device like A/C or AIR pump. I do not think the bracket is correct so maybe someone updated the alternator?
If I had a 3G I would not have the external regulator correct?
I have heard good and bad about testing these parts. Mostly because the parts store guys have no experience using the gear. I just paid $100 to get it towed so I would need to take the parts off and get them tested at the store. They MAY get it tested right if it was all together and running but I have no faith in doing component testing...
broncnaz
Some broncos had smog pumps might explain the bracket. The parts stores testors are pretty simple I dont really see how they can not use them correctly but Still a actual test on machines is better than you guessing. Even if its just taking the parts to them. Does the bronco currently start and run? It should be able to run to the parts store and back in the day time if the battery is in good condition.
Steve83
Key off:
Because the voltage at the alternator and at the battery are so close...
I wouldn't call those "close". Those 1-3V differences suggest some HIGH resistance in your wiring, especially since they appear with very low current flow.
How do I "full field" the regulator...?
You don't; the regulator has no field. You full-field the ALTERNATOR by powering the F (Field) circuit while the alternator is spinning (engine running ~1500RPM). If you look VERY closely at the VR connector, you should see the letters debossed in the plastic. Simply jumper F to battery (+) - don't disconnect anything. You can attach the jumper at the VR, or at the corresponding terminal on the alternator. It works similarly to what this caption describes, other than the polarity of the F terminal:
pcf_mark
pcf_mark
Good news! Sort of.. I found the root cause of the problem. The big positive wiring going to the starter was melted on to the header tube. I am not sure how it started.
When I grounded F at the regulator the voltage at the battery did not change. I also tried to ground the F on the back of the alternator and same results.
Should I assume the alternator is toast at this point? Since the red wire to the starter only gets voltage when the key is in the crank position I guess it did not drain the batter down or cause a short except when cranking. I am not sure how this could have wiped out the regulator or alternator.
pcf_mark
pcf_mark
I took the alternator to Advance and they tested it for free. Twice - while I watched. It passed the test so that was good. I did not take the VR but I did purchase a replacement. I tried both '68 Bronco and '78 Granada and they have been superseded to the same part so they are all solid state now.
My plan is to un-tape the wiring harness in the front and give it a good once over and clean all the connections. Then install the new VR (battery disconnected) and re-install the alternator. Hopefully I will get 13-14V across the battery with the engine running.
Oh yeah - I am also going to replace the melted starter wire and tie it up properly. I'll let you know how I make out.
The "F" terminal does not full field when grounded, it full fields when powered up.
When it shorted to ground it took out the voltage regulator. As the output of the regulator was shorted to ground the regulator couldn't take it.
pcf_mark
pcf_mark
Ok that explains a few things. Today I replaced the wires going to the alternator because the quick connector was hacked up. Black/red to pos on the alt, tan to field and black to the ground on the alt. I also added a ground from alternator, over to the starter relay, over to the voltage regulator and then back to the battery. I have the same voltage in all places now.
I also ran a new wire to the starter.
Now the Bronco is completly dead. I charged the battery but knew it was not that because it ran when I started working on it today. I jumped a wire across the starter relay and it sparked a crap load. By dead I mean the entire truck has no power. No head lights, brake lights, starter. Apparently I disturbed something important. I checked and I have 12V at the post on the starter solenoid where the wiring harness is connected.
Any pointers? I have been over it several times and do not see what I screwed up..
