Left me stranded - charging system question
Viperwolf1
electron whisperer
Now the Bronco is completly dead. I charged the battery but knew it was not that because it ran when I started working on it today. I jumped a wire across the starter relay and it sparked a crap load. By dead I mean the entire truck has no power. No head lights, brake lights, starter. Apparently I disturbed something important. I checked and I have 12V at the post on the starter solenoid where the wiring harness is connected.
Any pointers? I have been over it several times and do not see what I screwed up..
Loose wires on battery side of the solenoid, crappy battery terminals, blown fusible link, etc.
pcf_mark
pcf_mark
This is really baffling. I took your advice Viperwolf and checked my connections at the battery and the solenoid and they are clean and tight. I have 12V on the yellow wires over at the VR when going to ground on both the VR and engine. Is this after the fusible link in the harness? It appears to be in this drawing http://seabiscuit68.tripod.com/images/68-71ignition-color.gif. Otherwise I guess I need to unwrap the harness to find it because I do not see one sticking out anywhere in the area around the starter solenoid and alternator.
Viperwolf1
electron whisperer
It's probably wrapped. One end of it should be at the solenoid.
RRRAAAYYY2
Brantford, Ontario
I wouldn't call those "close". Those 1-3V differences suggest some HIGH resistance in your wiring, especially since they appear with very low current flow.You don't; the regulator has no field. You full-field the ALTERNATOR by grounding the F (Field) circuit while the alternator is spinning (engine running ~1500RPM). If you look VERY closely at the VR connector, you should see the letters debossed in the plastic. Simply jumper F to ground - don't disconnect anything. You can attach the jumper at the VR, or at the corresponding terminal on the alternator. It works exactly the same as this caption describes:
The only exernally regulated alternator you full field by grounding the F terminal is a Chrysler. The Ford F needs to have a positive source of power, and is grounded internally in the alternator. If you try grounding the terminal it can and will damage the external regulator.
I think you are thinking of 2Gs.
RRRAAAYYY2
Brantford, Ontario
Ok that explains a few things. Today I replaced the wires going to the alternator because the quick connector was hacked up. Black/red to pos on the alt, tan to field and black to the ground on the alt. I also added a ground from alternator, over to the starter relay, over to the voltage regulator and then back to the battery. I have the same voltage in all places now.
I also ran a new wire to the starter.
Did you put all the wires back on the solenoid correctly, if you have the power ot the cab on the same side as the starter, it will be dead.
pcf_mark
pcf_mark
I went over it another time an dunwrapped the harness from the alt to regulator. All the wiring is correctly installed/routed. I did double check that I did not have the black power lead for the harness on the wrong side it was correct. I do not have a fuse link anymore but the wires are all going to the correct places. I traced it all the way to the bulkhead connector and I have power on one pin. I beleive this is the same wire that goes to the solenoid where the positive lead attaches. Looking at the firewall it is the left connector, left side, second up from the bottom.
There is no power inside the cab at all. On the wiring diagram in the link below it looks like power is routed from the solenoid to the bulkhead connector into the ammeter (whici has never worked) to some kind of distribution union. Then back through the bulkhead connector all the way back to pos post on the alternator. If all that is correct I should have 12V at the alt lead with the key off if this circuit is unbroken. Can anyone verify that???
Also I used my bypass switch and was able to crank the engine for a second bypassing the solenoid.
Viperwolf1
electron whisperer
Yep. That firewall connector was only used a few years and it sucks. I replaced mine with a terminal strip because it was in bad shape.
Steve83
Both 2G & 3G ground the F terminal, as that diagram indicates. 4G & 5G don't have an accessible F terminal, but they also ground the Field to generate power.
But after looking at the eB wiring diagrams, I see I was mistaken about these old 1Gs with external regulators. :-[ They power the F, and ground internally all the time. I've edited post #16.
Yes, every point on circuits 38 & 37 should be hot at all times.
Where exactly did you connect the switch leads, and did the engine run, or was it only the starter that engaged?
BTW
Apparently, that Tripod site doesn't allow remote linking, so use this: Seabiscuit68's COLOR eB Wiring Diagrams Then click the '68-71 Ignition link.
Key off:
Across posts on battery: 12.65 volts
dual orange or yellow at regulator: 10.00
green at regulator: 0
red at regulator:0
Key on engine off:
Across posts on battery: 12.57 volts
dual orange or yellow at regulator: 12.46
green at regulator: 12.15
red at regulator:12.3
Key on engine running:
Across posts on battery: 12.25 volts
dual orange or yellow at regulator: 12.32
green at regulator: 11.45
red at regulator:12.10
From hot post on alternator to ground at case: 11.83
From hot post on alternator to ground at battery: 11.88
Hey Mark, back to something you said previously and Steve commented on. Some of your variations are WAY out of line. Not close at all.
With simple vehicle wiring, like on an EB, just a couple of tenths of a volt difference mean too much resistance in a wire, or a faulty connection somewhere.
And on the large Black wires between the alternator and the starter relay you should have exactly the same voltage. Yours is especially way off there.
I know you said since then that you've cleaned up a bunch of wires and checked others. Have you re-checked these numbers yet? Pay particular attention to the Yellow and Green w/red wires at the alternator. When the key is on, they should read exactly the same. Exactly.
The drip in voltage on the Yellow wire when the key is on says something, but I'm not sure what yet.
And the large Black wire between the alternator and the battery should be exact also. There is a simple bullet connector near the ammeter where there is a break in the wire so it can be fed through the ammeter's loop. Find that connector, pull it apart and clean it up. Make sure it's very tight when it clicks back together. That's where ALL of your vehicle's power runs through.
What year did you say yours was? I think you were just saying it's got the firewall connectors, right? If so, make doubly-sure that both of those connectors and their alternate halves on the inside of the firewall are making very good contact and that no wires are crimped under the floor-mounted fuse panel, or have any rubbed-bare spots, or are loose in their sockets.
All of the above are critical to a properly performing charging system.
pcf_mark
pcf_mark
Thanks guys.
I will try to find 37/38 in the cab and see if I have 12V tonight at the ammeter bullet connector. I did clean the bulkhead connector becasue my '68 has this beauty of a design!
When I jumped the solenoid I only let it crank a second to check the power of the battery. I did not try to start because I do not think there is 12V anywhere in the engine compartment except 37/38.
I replaced the wiring from the harness to the alternator because the quick connect was cut up and taped together. I think this was my reistance. This should fix my voltage variations. I have 12.8 on this circuit now both over at the regulator and across the battery. I have not tried at the alternator. I'll repeat the tests from my first post to see if I fixed this. Starting off a "charging problem" now it is a "not running" problem!
Assuming I totally hosed up fixing these wires I disconnected them from the alt. No change. When I connect the negative side of the battery I do not get any spark indicating a short of discharge either.
pcf_mark
pcf_mark
I feel like part idiot part sleuth. The issue was the large ring tongue that connects the harness to the solenoid. I cleaned this but failed to notice the electrical tape (i thought it was shrink tube) over where it would be crimped. Seems the crimp was cheesy and the tape was holding it in place. I discoverd it by leaving the headlights on and wiggling each connection until the lights flickered.
Now back to my charging problem...
I repeated my tests to check the voltage and here they are:
Key off
Battery 12.51
Yellow at regulator 12.50
Green at regulator 0
Red at regulator 0
Alt + 12.54
Alt F 0
Key on engine off
Battery 12.53
Yellow at regulator 12.49
Red at regulator 0
Alt + 12.54
Alt F 0
Key on engine on
Battery 12.32
Yellow at regulator 12.36
Green at regulator ~1 very low and hard to probe these connections
Red at regulator ~1 very low and hard to probe these connections
Alt + did not check
Alt F did not check
When I turned on the lights I checked
Alt+ 11.95
Alt F 8.6
I do not think it is charging because the voltage with the engine running is less than when not running. However I am getting volts on the F term terminal indicating it is getting a charging signal. I have no idea what the low voltage readings are about on the green and red at the regulator.
This is with a NEW regulator (grounded before install) and fully charged battery.
Good news it is running and the high resistance is gone in the circuit. Bad news I do not think it is charging...
Viperwolf1
electron whisperer
The regulator and alternator won't work if the green-red wire at the regulator doesn't have 12V with the key on. Look at the back of the ignition switch to see if it's connected.
Steve83
Don't feel bad - I helped fix a brand new $50K LR3 that was built that way at the factory. It wasn't a problem until the new owner attempted to drive from NC to CA. The terminal worked free somewhere near Jackson, TN, and he didn't notice that the trans had dropped into limp mode (2nd gear) at 85mph until the engine literally melted down & locked up. So consider yourself a GENIOUS for not having THAT big a problem. ;)
Key off
Battery 12.51
Alt + 12.54
Much better, but the only way to have higher voltage at the Alt+ than the Batt+ with the engine off is if there's a lot of corrosion where you touched the meter probes. It's not causing your charging problem, but it indicates your terminals could be a little cleaner.
Key on engine off
Battery 12.53
The higher key-on Batt+ voltage suggests the same thing - corrosion (resistance) where you touched the meter leads to test battery voltage.
Key on engine on
Battery 12.32
Alt+ 11.95
Alt F 8.6
These tests are more useful if you test each point under the same conditions, but this should be enough info anyway.
Exactly right.
Yeah, but not nearly high enough. That's just backfeeding thru the VR's resistors.
The green (Green/Red) is the main problem. It should be almost battery voltage any time the key is on. The other (should be Orange, right?) should never have any voltage - it's a ground from the alternator to the VR. Clean & tighten it at both ends.
This is with a ... fully charged battery.
Good job!
Too many people skip that step!
pcf_mark
pcf_mark
I went over my connections (again!) and they seem clean and tight. I think my voltage variation was caused by me trying to probe the VR connection from behind. Key on engine off I now I have 12.5 volts at the VR on the green/red and yellow. The red one is always zero - I assume this is because it is the output to the alt when the VR says it is time to charge.
Because I did not know what or how else to test anything I tried to the field test on the alt with the car running. I connected my meter across the battery engine off and had 12.50 volts. With the VR disconnected I started the engine. Across the battery I now have about 12.3 (nothing else is on except ignition). Then I jumped from the positive post to the F field of the alternator. I beleive this should have "full fielded" the alternator and it should charge full blast. The reading across the battery did not change at all.
This sounds like the alternator is bad even though Advance tested it and said it was good. Correct?
Viperwolf1
electron whisperer
Yes sounds like the alt is bad.
What is the red wire connected to? Shouldn't be a red there.
pcf_mark
pcf_mark
Here is the routing of everything to avoid any foul ups:
At the VR
2 yellows in one connector: one ges to the batt side of the starter solenoid the olther is terminated in a quick disconnect butt connector (Ford)
Green/red strip: into harness toward firewall, i believe all the way back to the key
Orange (not red as I thought once I got down into the part of the harness that was wrapped) goes to the F terminal on the alt
At the Alt
Alt Pos post is connected to a black/yellow stripe into the harness i believe all the way back to the ammeter
F post is connected to orange wire from VR
Grd post is connected to a black/purple stripe that goes over to the VR mounting screw as a ground.
As I noted I also added a ground from the battery to the starter solenoid, over the alt grd and back to the other mounting screw on the VR to be sure they are all happy.
If I need to buy an alternator can I get a 3G that will bolt into the 1G brackets? If so what do I ask for? And I am going to need research the wiring too! Edit - after reading about the 3G possibly needing a wiring upgrade for the ammeter circuit I am not too excited about it now. What vehicle uses a 65-70 amp 1G?
RRRAAAYYY2
Brantford, Ontario
You only need to add a 4ga wire from the back of the 3G over to the battery, then you dont have to worry about the ammeter circuit. You could probably use a 6 or 8ga if you wanted to. I would then take the wire that originally went from the alternator to the amp guage, and connect it to the battery side of the solenoid. This would give you two feeds into the cab. It would however make your ammeter useless, which it already really is, but that is besides the point.
Viperwolf1
electron whisperer
I agree but would add a fusible link to original charge wire before it gets connected to the solenoid. There is one on the other end that is already attached to the solenoid but it won't do any good if both ends are attached there.
Steve83
You don't need to upgrade any wiring for the 3G, unless you have large non-stock electrical loads in the truck wiring. If they're attached to the starter relay (like a winch), the stock wiring will be fine. Just connect the alternator output to the starter relay, with the battery (+) cable. The ammeter will then show how much the truck is consuming (if it shows anything now) rather than what the battery is doing.
Can you post pics of your engine bay, showing your current alternator, bracket, & belt?
pcf_mark
pcf_mark
Thanks guys I wanted to follow up now that this is resolved. Important lesson: never, ever spend any money on a 1G and ext regulator because it is a waste! I threw $18 at a VR after the alt tested "good". Worthless.
I bought a 3G from a '96 Mustang for $25 with the factory wiring including the main hot lead. Ground the big cast iron bracket a bit. Installed and re-used the same belt. Did some wiring as discussed (I need to go back and add the fuse link on the Blk/Yel). Works AMAZING! My headlights are actually bright at idle! My heater fan seems to have more spunk now too.
I also cleaned all the battery cable connections for good measure.
After the disc brakes / hydro boost this is the best upgrade yet!
