redtail
- Jul 14, 2010
- 621
Replacing the stock open carrier with a locker.
Old setup had a fairly consistent .014 backlash. When I installed the locker I set the backlash at .010 and checked it at several places, I had the backlash wander around from .006-.014. and sometimes more. There was a few spots of rust on three of the teeth (grouped together on the ring gear, so I could tell where they were. however that does not explain the other areas being out of whack.
I noticed it looked like the locker had been dropped on its edge at one point, and had some scarring that I had to file down.
I also noticed that the gear pattern was nutty as *ell, it seems to walk from the heel towards the toe. starts in the middle with a good pattern, center toe/heel center root/tip, coast and drive side, then the pattern walks from the center toe/heel all the way almost off the gear, to the toe side. then after a few teeth it just pops up into the center again and works its way back to the toe.
any ideas?
any ideas?
