Looking for pics of Lokar’s 6R80 (or other similar floor shifters) shifter installed in a Bronco
WPS 73 Bronco
The Woodlands, Tx
I want to see how the surface mount sport shifter install looks. Did you build a console box around it to hide the bottom of it?
Lets see some interior pics. How did you dress it up?
WPS 73 Bronco
WPS 73 Bronco
The Woodlands, Tx
I changed the title to include other similar examples. What I'm really looking for are pics of how you've added a console or something else around the shifters to make it look good.
Howard2x4x4
Similar circumstance, with an added twist...... C4 tranny, easy enuff, but I went with a 1987 F150 tilt steering coloumn, so that muddied the water a bit. I also wanted to ditch the foot pedal e-brake because - well, just because. And I wanted a center console because, well, just because. I did buy a Pinto hand e-brake figuring I'd flesh it out eventually, but I switched course.
Instead of fleshing out the Pinto e-brake' I started wandering thru pick-n-pulls for something Ford that was closer to what I had in mind. Found a Ford model with a console mount shifter and e-brake. So far so good, but the console mount late model shifter didn't want to play nice with the vintage C4. Made another course correction and picked up a Pinto/Mustang II C4 console shifter and bezel and a hand e-brake lever from the late model p & p Ford. Had to elevate the shifter and e-brake a bit to accomodate the console. 20240113_101101.jpg Fabricated the e-brake and shifter mounts and a bracket to hold the shift cable. 20240113_110550.jpg Had to modify the console a bit because Ford apparently didn't plan it going in an EB. No big deal, just need some plastic paint to pretty it up a bit. 20240113_110752.jpg Put a few of the factory pieces and parts back together, and the C4 bezel in place. 20240113_135400.jpg The shifter bezel adds a nice period look, imho. The tranny shift knob, TC shift knob, and the heated seat switches still need tweaking, as does the radio. 20240113_135432.jpg The shifter knobs are windshield knobs I bought used on Ebuy. They match the instrument panel knobs. Had a machinist buddy modify one to go atop the Hurst shifter I'm using for the TC. Still need to get a vision for the C4 shifter knob. Where there' a will, there's a way. 20240113_135409.jpg
Gotta fine tune some knobs, and configure the TC shifter, and get the radio installed somehow. One day at a time, one project at a time.
Howard in beautiful and blizzardy and blustery west Michigan.
anoblefox
all shaft operated, only a 5/8" hole through floor; no cables
Colo77Bronco
Colorado Springs
Really smart! Seems like cable mounting bracketed is the biggest challenge with 6r80/10R80 in our rigs with the limited space in that area especially with an Atlas. Many go back to column shift because a solid linkage doesn't need additional bracketry. You may have saved me a ton of time!
Pics of what you ended up with?
I run a Winters, custom console that I mated with my 20 yr old Tuffy, cable shifters and a ProCase (Atlas externals). My shifter cable comes in from the front.
WPS 73 Bronco
WPS 73 Bronco
The Woodlands, Tx
Here's where I ended up. Dan Carr custom console with Lokar ss shifter and JB twin shifter, both cable drive to a 6L80 and AS Atlas TC. It's designed to mate up to my existing Tuffy console.
