Don't know about pulling the core without the key, you've got to turn the thing to ACC to expose the pin.<br>You could always just pull the connector off the back and hotwire the thing to move it, just connect the run (resistor) wire terminal and the accessory wire (unsure about the color, but it ain't the dual red/black wires-those are the start circuit) to the batt (yellow) terminal.<br>Then get under the hood and jump from the S terminal to the hotwire on the starter relay and the thing will start. Don't leave that last jumped, just until it starts.<br><br>OR, you could get a locksmith or a buddy with some picks out<br><br>OR, you could just drill out the core and start it with a screwdriver, then get a new core. Cheap.<br><br>Ed<br>
