LOWERING my Bronco
greatguy57078
greatguy57078
:D I picked up a '77 rear end, and the complete '79 Lincoln Versaille disc brake setup, right down to the emergency brake cable. Now I need to find the 31 spline parts I need.;D
backpain
I think you should seriously consider chopping the top if you lower it. With all the glass so flat, it will be easier than on a lot of other vehicles. Potential for a really good looker. But keep in mind, it will be a tiny vehicle.
Some may say you'll end up with something reminiscent of a Scout, but it will still be an EB in my book.
robofig
Lowering an early bronco! I think you should be banished to the dark side. Go buy a Honda Civic.
Fishbone
Northern, Illinois
I'm lookin' forward to following this project. I've had a pic of that blue one saved for a long time now. An EB would make a great hot rod, small, light, full frame, and a simple design.
Keep us updated!;D
behemoth
I am about to order parts and get committed, but my new concern is the rake front to rear. All of the pictures I have seen all show about the same amount of rake 3". It is a little to stink bug for me. I was hoping to get the rear down just a little more. The rear suspension and the frame "c" I do not see enough room to bring it down any. Am I missing something ? I have looked under my own truck and the space between the frame and the body for the "C" just does not appear to be enough. Any thoughts on bringing the rears down a little more? custom mono spring ?
greatguy57078
greatguy57078
Notched Frame
Filp the axle on top of the leafs, and notch the frame using something like this kit that I picked up on eBay. You can cut the pieces to fit the application, and weld it up before you cut into the frame. I hope to get a good start on mine as soon as the weather breaks.:cool:
behemoth
could a 4 link be a simple swap at this point ? I was just thinking of eliminating the leafs all together ? what would it take to do this ?
I was thinking of using the front leaf eyes on the frame for the parallel bars and adding the angle bars to the frame near the c notch. Travel is not an issue as there is not a whole lot in this setup to begin with.
Any thoughts ?
greatguy57078
greatguy57078
:cool: No new progress yet. There is a guy that makes a adapter kit to use a Lincoln or Mercury IRS. It looks pretty staight forward, but I am not sure if I want to complicate this any more than I already have?:eek:
WyleCoyote
At first I was a little put off by this idea, but after looking through the thread and seeing the other pics, I like it! Do it right and make it look great!
Crewwzin
Freeport, Fl
I really like this idea and have wanted to do one like it for some time. I would go a slightly different route and use airbags and the front clip off of a early '90s Toyota pickup. Before someone gets all crazy on me let me explain. You get the frame from the firewall forward which includes upper and lower a-arms, disk brakes and a 5 on 4.5 lug pattern. Use a Mustang or Explorer 8.8 rear and you have matching lug patterns. The Toyota front-end has aftermarket parts galore for a 'bag setup and the framerails are about the same width as an EB. You have the right idea with the c-notch in the rear.
I look forward with eager anticipation to the rest of this thread.
behemoth
There is a suspension somewhere headed for my home. There is an 8.8 in the garage waiting to replace the for 9 which gets you the correct bolt pattern, disks, a locker, and 31 spline axles. There is a c notch kit in the garage as well.
As many have said if done right they look great, getting the stance right is the issue.
I was initially thrown off by the cost of the mustang II suspension vs just keeping it stock and 0 lift.
After adding up the cost of the disk brake conversion, a power steering conversion, new tie rods and drag link the mustang II is cheaper to equal cost.
What I did to make it more difficult is add an aod trans, an explorer engine with efi mustang, and the explorer rear.
There is still way to much to do but I hope to have mine ugly but running in 19 days. ouch.
Bill
Tito
CB Fire Starter
Bakersfield, CA
Bill
Thats awesome Bill! I hope you can pull it off, really looking forward to seeing more out there to get ideas from. How come you didnt go with a 4r70w 2wd trans? I guess the 2wd AOD is pretty affordable and overabundant huh?
behemoth
Well I hit the first snag today with the cross member. I was expecting a part set up for a bronco as that is what I ordered. I received a universal part which will work but is not ideal. I will have to clarify it with the company before I get started on this.
The transmission I chose was the mustang aod to avoid any expensive electronic controls or odd parts. The aod is everywhere.
Bill
greatguy57078
greatguy57078
I am sorry that yours was not cut, and it looks like mine wasn't either. I am downloading pics and will have them up here in a few mintes. Mine looks exactly like yours. I hope that we can both get this straightened out. From my experience, the guys there at JPL are very good with their customer service. Stay tuned...
Here are a couple pics of what it should actually look like when welded to the Bronco frame. It does look like more work than I thought, but nothing that I could not do with a cutoff and square it up on the mill if necessay(but I have access to mills/lathes,etc). I was expecting it to be precut also. I guess I should have looked closer...
behemoth
Well the name on the cross member is where that came from but the company that put the order in to them was different. I will hold off on the name until they have a chance to straighten it or me out.
the hats and the cross member will get the crap cut out of them to fit the bronco.
I am working a back up plan but things are not looking good... oh well no big deal either way.
I think of this truck as the turd, but in reality it will be a poor mans mustang gt convertible. If I wanted a civic I would have bought one. Hey at least I did not cut it ;D ,
Not a problem, I will give them a call in the am and see what they can do to help. I have looked at these photos so much I know where he put his cross member. I also noticed that there is no way to install the cross member with out removing the engine stands. The engine stands will also be cut up pretty good. The drivers side will also have a hole cut in it for the steering shaft to go through.
We shall see in the am.
