LOWERING my Bronco
Broncoholic1
Lookin good! I will keep on lookin in to see your progress.. Might have to get one of them goin
greatguy57078
greatguy57078
The weather is not cooperating. It looks like we are on for this Friday. Look for an update (with pics) soon.
greatguy57078
greatguy57078
We got the spring towers fitted in place, and tacked them in. They sit level with the crossmember, taking into account the approximate 3" rake we are shooting for. If the math is right it should be close.
greatguy57078
greatguy57078
We moved on to the frame notch, while we had the frame right side up. The rear brake bracket located on the drivers side was removed with the torch.
greatguy57078
greatguy57078
I used the bump stops as a center line for the notch. We lined up the side pieces of the notch kit making sure that they maintained square with each other, as well as the side of the frame itself. The sides and top cap were tacked into place.
greatguy57078
greatguy57078
With the top and sides tacked in place, we flipped the frame upside down. That makes it easy to torch out the notch, which includes the stock bump stop assembly. After torching them out the area is then ground to allow the bottom cap to be layed in place and tacked welded in.
greatguy57078
greatguy57078
I really like the look. Very clean and smooth, and it really should be stronger than stock. I will post more pics when the welds are finished and ground smooth.
greatguy57078
greatguy57078
We did some more grinding and welding today. I smoothed and cleaned up the welds, and it looks good. Tomorrow we will finish the welds, and fit the A arms into the crossmember. I do not want to assemble everything with the coils installed yet, as it will be going back to sandblast and then on to galvanized dipping. I will post more pics of our progress tomorrow when I get home.
greatguy57078
greatguy57078
Finished the welding for the Mustang II IFS and the rear notch. After the welding was done, I ground and polished up the welds with a 4 1/2" grinder and a belt sander. My partner thought that I was getting pretty picky using the sander but it allowed me to get into the tight corners better. He prefers to use a flapper wheel. Next we will be bolting in the A arms and rack to confirm the fit and function. We are close to setting in the 4.6 DOHC and mocking up the mounts. Sorry about the blurry pics. Maybe I need to clean my lense on my camera...
behemoth
It all looks really good, and strangely familiar.;D
Sitting idle with mine after purchasing a big gas tank that will not work on a lowered bronco. That and the thought of cleaning and coating the underside of the tub before putting the frame back.
greatguy57078
greatguy57078
Thanks again behemoth! The notch kit worked out great. I am going to have my frame galvanize dipped when we get it done. It has to be planned out and scheduled, as it will have to be driven straight over from the sandblaster and dipped into the tank right away. Otherwise the galvanized coating might not stick properly, according to the tech guy.
greatguy57078
greatguy57078
I was thinking of using the original tank. I was hoping to be able to make it work with the EFI on the 4.6 DOHC.
behemoth
There is no real issue in using the original tank if it is in good condition. I just wanted to run an in tank pump to keep the frame rails as clear as possible. With the lowered suspension and the 4 link I did not figure there would be a whole lot of room for a pump, filter, and exhaust to run through there.
In the end for me I will probably have to get a custom tank to use an in tank pump and keep the ground clearance for the tank.
behemoth
cheaper to lift one, buy bigger tires, and re gear both axles than it is to lower it.
Stock height, stock suspension and be done with it.
broncomitch
west jordan, utah
about what i was thinking. but it would be a cool little driver.. i was thinking taking the coils out and lower the front end till i have about 2 1/2" from the closest point the the frame and axle and getting custom coils made...or air bags or coil over. with large rims 17'' or 20"s and do a spring under in the back. i have the drivetrain out of a 2001 svt lightning........;)
greatguy57078
greatguy57078
I found a set of NOS Ford Musang II upper A arm bolts online. After setting the lower A arms up to the crossmember, I realized that I was about 5/16" long on the back tubes where they mount. Now I know why the guy at Heidt's wanted to know if I wanted them to weld them in, or wait and weld them in myself. I trimmed off the extra 5/16" and cleaned up the ends. The A arms bolted right up!
greatguy57078
greatguy57078
Next on the list will be setting the motor mount towers back into place. We had to cut them off in order to weld the Mustang II crossmember in position. I will clean them up and then we can bolt them to the Mark VIII using the custom made motor mounts (Tumblin Automotive).
behemoth
odd that the stand offs were to long. that was one thing that was correct on both of my cross members.
