LOWERING my Bronco
greatguy57078
greatguy57078
FYI - Three inches chopped off the top equals out to be about 2.75" cut out of the window frame. Here is what it looks like. Thank you Dale for the updated pic.
greatguy57078
greatguy57078
uncut tub * FOR SURE
Mustang II front end *DONE DEAL
Explorer rear with discs and tru trac *OR HD 9"?
F/R sway bars *4 LINK AND PANHARD BAR
air bag suspension *COILOVERS
front and rear roll pans* ABSOLUTELY w/LIGHTS and EXHAUST CUT OUTS
shaved door handles*AND SUICIDE!!
lowered floor boards/ tunnel work and low profile seats *WHEN NECCESSARY
chop windshield and door frames as low as comfortable. * SCHEDULED
LS6 with a 6 speed manual * 4.6 DOHC 32 VALVE w/5 SPEED
motorized soft top * I am keeping the hard top and...TO BE REVEALED LATER
brushed aluminium behind seat roll hoops * FULL CUSTOM ROLL CAGE
metalic silver paint * BLUE? RED? GREEN?
vintage air * UH HUH
power windows * REMOVABLE AND CUT 3"
17" wheels
tubbed rear NOT necessary
CUSTOM filled in tail gate
That should JUST ABOUT do it. Of course I could always change my direction... again...
bronko69er
EB Addict
Renton, WA
How did you deal with the top edge of the window frame? as it would need to get longer when it is lowered.
And is the reason for not making the rear sit more level an asthetics thing? or is it to keep from sheet metal work in the bed to accomodate the notched frame and tire stuffing?
greatguy57078
greatguy57078
You have to add a section across the top, as well as another small section to the top of the window frame, as they both "grow" wider front to back when you push them down. I personally prefer the raked look rather than the "slammed" level look.
Tito
CB Fire Starter
Bakersfield, CA
Holy $hit that is looking good!!!!!! Oh man, soon, very soon! Maybe I wont be building a mustang next after all.
Tito
CB Fire Starter
Bakersfield, CA
What do you guys think about hoods?
Stock? Pro Flow? GTX? Other?
Anyone going to run efi under theirs? I am thinking explorer motor, efi will fit without a body lift if you mod the oil filler and the ps reservoir I believe.
behemoth
The hood will stay stock, but I am planning on putting the thunderbolt hood scoop (teardrop). Only for appearance though.
I am going to put in an explorer 302 with efi, with an aod behind it.
The valve covers can get changed to the mustang setup and fit fine or lower the fill tube on the exploder. The power steering pump tank will get lowered or swapped for a different shape (lower).
greatguy57078
greatguy57078
I want to stick with a stock steel hood. I will fab in a steel cowl insert or louvers, or both. With a BIG FAT 4.6 DOHC underneath!
behemoth
light o day
Well we pushed it outside for the first time in at least a year. nothing much going on.
greatguy57078
greatguy57078
I like! That really gets me going now! The 4 link should be here tomorrow, so I'd better get that 9 inch pulled! My updates will be coming this week! Thanks Bill... for the motivation!
greatguy57078
greatguy57078
Well... I was SO close to getting the rear out. I broke a Craftsman ratchet, and run into some stubborn brakelines that wouldn't budge without a line wrench, (which I didn't happen to have the right size for!). It should be short work tomorrow to finish the removal process. The kit is in Omaha tonight, and due to be delivered tomorrow afternoon. We should have a better idea what it will involve to install the 4 link by tomorrow night. I will have some pretty pictures of the kit installed by this weekend. Thank God for the warmer weather!
BroncoProject
Modesto
I think my voice has already been covered but I think if you moved that dana out and looked for a mustang pan or something along that line you would have a lot less issues. Also; What the heck? Lower?
behemoth
i am running the explorer 5.0 pan in mine, with the new crossmember location for the mustang II a rear sump pan would be required. I will fiind out shortly about the explorer pan, I do not see any reason why it would not work or why the bronco pan would not work. The crossmember is in the same basic location as the front diff was. It currently sits lower than the stock crossmember to begin with.
Hopefully this will be a non issue, but we shall see.
Tito
CB Fire Starter
Bakersfield, CA
Hey Bill, I dont remember if you covered this or not but how low do you think you could get it while still keeping the d30 in it? I know the plethora of reasons for putting the mustangII setup in but was wondering about still keeping the 30?
phred
Earth
It keeps looking better. Keep up the good work and I'll keep gathering (stealing your) ideas for my 65 f100. Been planning to lower it since 1980 when i got it. It's been in storage since about '88 when I caught the bronco bug.
behemoth
earlier in this thread there is a brown and white one that still has its front diff.
You could get it pretty low keeping the front axle, but you would be really close to the frame, so any bump and you would hear the frame and axle meet.
To keep the ride where it could be the ifs is required for in the weeds. You could get the front lower than where mine hopes to sit, but it would take notching the frame in the front as well.
lots of stuff still yet to do,
Tito are you going to make fff on the 19th?
