LOWERING my Bronco
behemoth
The 400 is better than the 800 for the super spendy air ride air shock/bags, that I was looking at( only looking) for the front....
the body has to come off the frame again this week, not going well small snags, but nothing that cant be dealt with.
greatguy57078
greatguy57078
I went with coilovers, after asking a few people out in the street rod world. I have heard about the problems you have down the road with moisture in the system. I would imagine that it would be different depending on where you live and the humidity in that area. Maybe someone with experience can chime in here and give us their .02?
greatguy57078
greatguy57078
There have been a few bumps along the way, but that's what makes it fun in the end I think. When someone asks me how or why I did something a particular way, I can stand by my truck and tell them exactly why, because I did it! There are alot of guys that can't tell you anything about their rides because they just paid another guy to do the work. What can I say? I love my Bronco!:cool:
greatguy57078
greatguy57078
I am going back to the body shop this afternoon. I keep stopping by at the first of every month. He does collision repair mostly, but there is always 2-3 hot rods in the shop being chopped or restored. He does excellent work and gets the work done, but getting it in the door is the hard part!%) Hopefully I can drop off "old red" and he can start on the chop job. Mama sure would like her garage space back!:mad: I will be sure to take pics along the way!
behemoth
For the coils the diameters are .565 = the 325 spring rate light.
.580 = the 355 spring rate medium and the .590 = 365 spring rate heavy.
yeah the little bumps are just that little bumps, we get by them. It is a learning experience, the joy is in the process the end result is a bonus.
I hear you on with the moisture with the air system. There are ways to deal with it but the bonus is the ease of adjustment with the ride as well as ride height. I like the bags for the amount of tuck I plan to have in the rear fenders. Changing a tire would be a pain. So air up the bags fully and that gives me the room needed to change a tire if needed with a single jack.
I have been looking at coil overs for the front as an other option to avoid multiple coil purchases and cuts. The adjustability is needed I feel with these things.
We have gone back and forth with the rear suspension on mine 4 link, 3 link and so on. getting all things in there and clearing the drive shaft through its travel has been a little more than I expected. there is just not a whole lot of room under the truck with the narrow frame. It would be easyier if I would just cut the bed, but that still is not an option for me. Stock body, the bed floor is not an option. Later on I may drop the seat floor as well as rework the front innerfenders.
Any response from Dale on the inner fenders ?
greatguy57078
greatguy57078
The front coil springs I have are 13 3/8" at the tallest point. I am still trying to figureout my rear shock dilema. Anyone have any experience on this? I hate to buy more parts that are wrong!%)
greatguy57078
greatguy57078
After talking to the tech guy at Aldan Shocks out in Cali http://www.aldaneagle.com/index.html, I think I have come up with the solution. I may have to cut and modify VERY little to the inside rear of the wheel tubs. I looked at my '68, and they already have a small radius added there for shock clearance. If needed, I will just notch this out and weld in a larger radiused patch/piece. I have to call back to Aldan's tomorrow morning to talk to the sales guy. They should be in South Dakota by Thursday next week.
behemoth
My front coils are 13.5 in tall and they are .595 which makes them heavy+ I am about to order the light weight coils tomorrow am.
The shocks are pretty laid back but should work not much room at all in there.
Looking good though
greatguy57078
greatguy57078
I will have to check and see what the coil diameter is that I have. I am sitting here waiting for the guy from Aldans to call me back with prices. I think I came up with th shock I need, if my dimensions are correct.
greatguy57078
greatguy57078
I went back into work and got on the CAD. After studying the shock schematic and reading up about installation on the Aldan Shock site http://www.aldaneagle.com/install.html , I think I have a better understanding. I went with a 250 lbs. coil spring, and should be able to dial it lower and firmer if needed later.
greatguy57078
greatguy57078
With some CAD assistance from KURT, I was able to verify the shocks I need. I am going to modify a set of James Duff axle stops, so I have a little something between the axle and the frame besides steel. Big THANK YOU to Kurt for his time and talents!
behemoth
Since I am tired of messing with the front springs and guessing what the spring rate should be I am now leaning to the ms1375 coil overs. I need to call on the spring rate and see if I can get a lower spring rate in the 325 range for the front. At least this way I can somewhat control the height and dampening better than with cutting coils.
I have small threaded bump stops mounted in the arch of the c notch. they look similar to the stock front axle bump stops.
greatguy57078
greatguy57078
Can you use the coilover shocks with the Mustang II tubular A arms, or do you have to have specific A arms for those shocks?
behemoth
They work with the a arms, these are stud mount replacements. Specify the bolt size for the lower mount and that is it. These come with cheaper springs and more adjustment options as well as dampening.
greatguy57078
greatguy57078
What is a ms1375 shock? Have you looked at the QA1's? Or is that a QA1 part number?
greatguy57078
greatguy57078
It's been a long time since I even looked at the front assembly. Do the coilovers need to be studs at both ends, or just the top? I was thinking you had to have different bottom A arms to run coilovers.
behemoth
that is a qa1 kit partnumber from summit, jegs is a 3375 number, just search either for mustang II coilovers. the stud mount is only for the top, the bottom is an eye with spacers. The bolt size for the bottom is important.
Sprayed paint on the dash moments ago, looks ok waiting for the flash/tack to spray another coat. Of course there will be some more sanding and spraying again anyway. never get it done the first time.
Kurt
Badger State
It was my plasure to help you out. ;D
Nice talking to you on the phone.
behemoth
Here are some pics of the dash, I am not a painter I guess I do not have the patients to let paint dry.
There are some problems, but I will fix them when I paint the other side of the glove box lid, hinges and door panels.
Here is a pic of the front coil overs I am about to order in the am.
