LOWERING my Bronco
greatguy57078
greatguy57078
Looks great to me! I have the same problem. Not enough patience. I either don't wait long enough, or I just plain spray too much at a time. Needless to say, someone else will be doing all my painting.
greatguy57078
greatguy57078
Let me know how that coilover kit for the Mustang II goes. I will have to do the same thing I'm thinking. Hopefully I will have the rear done this week. The coilovers are on the way, so I have a couple days to get the top brackets modified. I am using modified under axle brackets to get the location I am looking for up top. I just hope I figured right on the ride height!
behemoth
Mid week motivation
Here are some shiney parts for the week.
It has a bladder, intank pump, foam, and is somewhere around 18 gallons.
The sticker has not been placed yet so it will get moved to someplace visible when it is installed.
After this the cover goes on the whole project, another deadline missed so we are putting it away.
I have not ordered the coil overs for the front, will wait a while on them.
Good luck and keep the pics coming.
greatguy57078
greatguy57078
I got the mounts from Speedway and modified them. They are made to weld UNDER the axle, but I am going to use them to position the coilovers right where I want them on TOP of the frame rail. I may have to do a little radius work on the backside of the bracket in order to make it fit snug up against the inner wheel well.
If I did my math right, the midde hole should be right at the 15" mark (from the bottom shock mount) that I am shooting for. That will leave me with 3 1/2" clearance between the axle and the frame rail, with the shock at 30 degrees at ride height.:cool:
behemoth
The front is a pain, the lower arms must be level to the ground or you have bump steer. So your ride height is set, and it is set low. If I was to do it again, I would notch the front to get it a little higher and more wiggle room.
BAGs are fine, cheaper initially, then way out of the budget later. Mine was never built to be a chipper. Front coil overs give me the adjustablility I need for height and ride I am after I think.
Its getting there, but the budget for toys is almost gone and there are many things yet to buy.
greatguy57078
greatguy57078
OMG! What a BEAUTIFUL tank! I have too many items to buy before I can spend that much money though. VERY nice! TOO bright Bill!:cool:
greatguy57078
greatguy57078
My truck is scheduled to go in for the 3" chop tomorrow. I would love to be able to remove the top and window frames and go with the full "roadster" look (when I want to).
Should I use my '68 doors, or cut into a set of doors that have non removable frames and modify them? Keep in mind these will also have shaved door handles and hidden hinges, so once modified there will be no going back...
behemoth
If you are going to modify them anyway then use the later model doors.
I am going to commit yet another bronco sin and cut my window frames.
I have a set of fiberglass half doors that I was planning on using for this project, but I think I will use them elsewhere. Possibly sell them to pay for parts.
Lots to do yet but getting things done.
bronko69er
EB Addict
Renton, WA
I just made a deal on an uncut last night, look like I'm right behind you guys.
I'll be starting my hot rod bronco later this year. Cant wait! Just picked a mustag II front clip too!!!!!
greatguy57078
greatguy57078
Hey bronko69er, don't forget the old saying on this site...pics or your lyin'!:eek:
greatguy57078
greatguy57078
OMG! I just found my new desktop! ;D
bronko69er
EB Addict
Renton, WA
We'll it wont be in my posession until I have completed the remodel of a room as part of the trade deal...... be here it is.
greatguy57078
greatguy57078
Looks like it's solid and straight. I alos like the fact that it is uncut. I just don't think it would look good as a street rod without the uncut look. Nice find!
I have an update on my rear coilover mounts. Give me a few minutes to get the pics resized...
bronko69er
EB Addict
Renton, WA
Its definately a fair trade
What is not pictuerd is the front right.
The grill is pushed in a few inches in the lower corner and the fender is bent too. Doesnt look to terrible of a job to fix. One of the PO's welded new floor pans over the old ones but the floors dont look too bad from the underside.
Other than that, there is not much rust on it. Some surface here and there but all the normal spots are solid. I can't wait to get goin on it.
greatguy57078
greatguy57078
The fancy coilovers didn't come UPS today, so I made a "mock shock" from a piece of 2" x 2" angle iron so we would have something to use as a template. I drilled two 5/8" holes 15 inches apart. We set the frame and the rear axle at what I determined to be my ride height.
Then we used the "mock shock" and a magnetic angle finder (Ace is the place!) to determine the approximate position of the top mount that I modified to use as my top bracket. Using a magnetic level to keep the mount parallel with the side of the frame, the mounts were tacked on. After we were sure they had maintained parallel, they were welded in solid.
After all the welding was finished, I double checked that everything had stayed where it was supposed to. From center to center they measure 15", and the angle reads 30 degrees. This is were it should all be sitting at ride height, with the weight of everything bolted on. Of course I will have to do a little cutting an welding on the inside wheel wells to get the mounts to clear, but it's not like I will be hauling anything...besides ass!:cool:
greatguy57078
greatguy57078
I forgot to mention the shock post mounts. These are nice parts (Mr. Roaster) that I got from Speedway Motors. They have 5/8" shafts and are made out of billet aluminum. The mounts and the posts turned out great, and should easily bring the shocks in line with the bottom axle mounts.
behemoth
Nice rear shock mounts, something I will be looking to get in the future.
Here are the teaser pics I spoke of.....
