LOWERING my Bronco
greatguy57078
greatguy57078
Here are a few pics to show what I am aiming for. I would refer to the person that I "borrowed" the pics from (bax maybe?), but I am not sure who it was other than I remember it was his dad's rig....maybe?
77bronco_ed
Get anything done over the weekend?
Checked the calander, Hudsonville swap meet and Broncorama are right around the corner
warm weather is near ;)
behemoth
I built some gap fillers for the doors, found some rattle can paint that comes kindof close and installed them. Working on building a cheap toneau cover for the back bed, just plywood and some kind of covering for the plywood.
Not much other than the eb tach showed up yesterday so that will go in sometime this week.
greatguy57078
greatguy57078
What tach did you get? The one that WH started selling that match the speedo? They have a place her locally that does bed covers for trucks all over the country. Very well made and function well. Truxedo
http://www.truxedo.com/
behemoth
Thats the tach, mine is mounted lower left side. Since I shortened my column on this side by 4" its a little tight. Those covers are nice, but I am going low budget. The bed on mine does not appear to be square anymore so I am glad I did not spend a lot on it.
greatguy57078
greatguy57078
Snap a pic of that tach in your truck when you have time. I think lower left is the only way to mount it, unles you have room straight up. Either way...I want one! :eek:
behemoth
Here it is just placed I have to wire it now and adjust it. I really would like one of these without the black face to match the cluster.
77bronco_ed
Mass buy on the tach right now.... Placed an order.
Marty did you/will you need to modify the firewall with the 4.6?
behemoth
Here are some pics of its current and close to final state. I think when the time comes for paint I will paint it the same brown color again.
I will be dropping the rear lower to achieve this ride height, it will require some bed floor cutting as well as some rear inner fenders.
77bronco_ed
It looks nice... What did you do to bring it down lower for the pictures?
It must not be low enough for ya yet?
behemoth
When I did the lowering my focus was on the front ride height and not cutting the bed.
I chose air bags for the rear to allow me to adjust the height as needed. So when I arrived at fab fords I aired down for this look. Its not a big drop, just an inch or two. I can drive it at this height but I hit the bump stops when I hit bumps.
So To keep this ride height I will have to trim some more out of the notch and french in the bump stop or move it out of the notch.
greatguy57078
greatguy57078
I am getting back into the swing...kinda? I am sidetracked right now cause the boy wants to drive the halfcab to prom this weekend. yeah....caught me right in the middle of swapping to disc brakes so I can slap on the big tires. I am VERY close to pulling the body off to set on the street rod frame, so an update is coming. Trust me, I am not a man with alot of patience..... so bear with me!:-X
greatguy57078
greatguy57078
Well ...alright. If you really want to know it all started when I saw that low half that Duffy built a looooooong time ago!
After looking at those pictures, I was thinking about the ride Todd gave me in the red racer at the Stampede in March. It just had a couple of little plexi wind deflectors that worked amazingly well. I wonder what your Bronco would look like without the windshield and only a little wind deflector for each seet. I am thinking of some of those late 50's to mid 60's road race cars that were similer. I think there was a famous thunderbird that was that way as well as a few others. As well as the Stoppe racer too.
behemoth
I am looking at the possiblilty of removing the steel at the top of the windshield.
