M5OD Manual clutch
66 Bronco Dave
For the guys that don’t like hydraulic clutch try this. Pretty easy fab
The inner shaft of hydraulic throw out bearing is same size as the manual
i cut the outer shaft installed on trans and it measured the the same distance from bellhousing face to shaft that bearing rides on
took measurements and fork and bearing are in same spot as in the manual transmission
Bajabrewer
Nice to know - I just hooked up my hydraulic clutch but if I don't like it it's nice to know there are options.
